2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Hacking rsrv/camessage.c
To: <[email protected]>, <[email protected]>
Cc: [email protected]
Date: Fri, 4 Jun 2010 10:56:06 +0100
I've realised that we're sharing a misunderstanding, at least I *think that's the case!
> > >              if ( pevext->msg.m_dataType == DBR_STRING
> > >                  && pevext->msg.m_count == 1 ) {
> > > I'm quite baffled.  Is there any reason not to *always* ship the
> > > entire 40 characters of the EPICS string as a matter of course?
> > > Or is this a fine grained optimisation to avoid shipping an
> > > extra average 20 bytes?
> > String fields on the database side are not limited to 40
> > characters long; the db_access API can't zero-terminate the
> > source buffer.  Make sure that this code isn't protecting
> > against that kind of condition, which is easiest to test
> > using a record with a name longer than 40 characters and
> > accessing its .NAME field.
I think our shared misunderstanding is in the role of DBR_STRING in our conversation.  I presume that your new pv$ strings are actually acquired through dbGetField(... DBR_CHAR, ..., &MAX_STRING_LEN, ...) -- in fact, they *must* be!
In particular, this means that the bit of code we're talking about is bogus ... except, perhaps, for the lingering issue of null termination, of which more presently.
My code seems to work ok with an overlength .NAME field: if a request is made for pv.NAME I get the name truncated to 39 characters (plus null termination), and a request for pv.NAME$ as DBR_CHAR returns the sensible string.  Interestingly I see some zero padding at the end of the char array, but presumably that's simply because dbGetField returns the entire maximum possible name length and doesn't update the request count.  Maybe a small fix worth doing...
So most of my remarks below are, I believe, me panicking!  Sorry about that.
However, I do have a bug: my IOC crashes if the name is too long, but the 3.14.11 detects the error.  I'm not sure how my code can be responsible, but I'll have to check.
> Ouch. OUCH.
> So I take it that such long string handling only applies to
> single strings, not to arrays of strings?  Is there a limit
> on the length of such strings?
> Unfortunately I see two nasty problems here, unless I'm
> missing something.
> Firstly, the call to the client database goes through
> dbGetField() which provides no information about the actual
> buffer size, merely about the number of elements -- so I
> *have* to conclude that there's a hard-wired implicit limit
> on the string length somewhere in this API, and presumably
> the dbGetField() call must have to guarantee to null
> terminate the string it returns!
> So let me see if I've got this right:
> dbGetField(dbaddr, DBR_STRING, buffer, popt, pn, pfl) copies
> up to MAX_STRING_LEN (some hard-wired constant I've not yet
> discovered) NULL terminated bytes to buffer[] if and ONLY IF
> *popt == 0 and *pn == 1.  If *pn > 1 then standard EPICS
> strings are copied,
Ok, all this has got to be bogus.  If a request is made through dbGetField for a DBR_STRING value, I feel confident that the call must restrict itself to the 40 characters it's been given.  What happens if the string is *exactly* 40 characters (no room for a null termination) is an amusing problem for the client ... at least, that's my first thought.
I'm inclined to take the view that it's the responsibility of dbGetField to do the null termination, which it seems to do for the strings I'm looking at, and certainly there isn't reliable DBR_*_STRING termination code anywhere.  I won't worry about this.
>  if *popt != 0 only predefined attributes
> are copied.  Is this right?  Is this specified anywhere?
> I'm looking at the EPICS Application Developer's Guide, and I
> see some odd things.  The guide implies that the value is
> always copied, but the code for db_get_field would generate a
> stack overwrite if that was the case.  I see reference to a
> dbBufferSize routine in the documentation, but this is not
> used anywhere in EPICS base, so I imagine it's bogus.
Unfortunately this bit above remains valid.  Haven't dug into the corresponding code yet, but would guess that the documentation is remiss.  Maybe dbBufferSize is designed for external consumption?  Otherwise it should be dropped!
> I can
> find no reference to this horrible long string handling you mention.
> Secondly, I can't see where enough room is allocated in the
> buffer passed to db_get_field() from read_field().  As far as
> I can tell, the buffer size allocation is computed by
> dbr_size_n() which, unless I'm hugely mistaken, allocates 40
> bytes for a string.
> My guess is that we get away with this (most of the time)
> because the buffer we use normally has plenty of room...
> What am I missing?  This would seem a particularly evil
> Heisenbug if I'm reading this right.
Ok, I think this above *all* wrong, just ignore it.
RE: Hacking rsrv/camessage.c michael.abbott
Prev: RE: Hacking rsrv/camessage.c michael.abbott
Next: [Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base Michael Abbott
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Hacking rsrv/camessage.c Jeff Hill
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
