Subject: |
[PATCH 3/4] Add autosizing array support for caget and camonitor. |
Michael Abbott <[email protected]> |
To: |
undisclosed-recipients:; |
Date: |
Wed, 2 Jun 2010 13:51:08 +0100 |
Signed-off-by: Michael Abbott <[email protected]>
src/catools/caget.c | 30 ++++++++++++++++--------------
src/catools/camonitor.c | 11 +++++------
src/catools/tool_lib.c | 6 +++---
src/catools/tool_lib.h | 4 ++--
4 files changed, 26 insertions(+), 25 deletions(-)
diff --git a/src/catools/caget.c b/src/catools/caget.c
index bae87e7..573ae85 100644
--- a/src/catools/caget.c
+++ b/src/catools/caget.c
@@ -127,6 +127,7 @@ static void event_handler (evargs args)
ppv->value = calloc(1, dbr_size_n(args.type, args.count));
memcpy(ppv->value, args.dbr, dbr_size_n(args.type, args.count));
ppv->onceConnected = 1;
+ ppv->nElems = args.count;
nRead++;
@@ -183,11 +184,9 @@ static int caget (pv *pvs, int nPvs, RequestT request, OutputT format,
/* Adjust array count */
- if (reqElems == 0 || pvs[n].nElems < reqElems){
- pvs[n].reqElems = pvs[n].nElems; /* Use full number of points */
- } else {
- pvs[n].reqElems = reqElems; /* Limit to specified number */
+ if (reqElems > pvs[n].nElems)
+ reqElems = pvs[n].nElems;
+ pvs[n].reqElems = reqElems;
/* Issue CA request */
@@ -205,13 +204,13 @@ static int caget (pv *pvs, int nPvs, RequestT request, OutputT format,
(void*)&pvs[n]);
} else {
/* Allocate value structure */
- pvs[n].value = calloc(1, dbr_size_n(pvs[n].dbrType, pvs[n].reqElems));
+ pvs[n].value = calloc(1, dbr_size_n(pvs[n].dbrType, pvs[n].nElems));
if(!pvs[n].value) {
fprintf(stderr,"Allocation failed\n");
return 1;
result = ca_array_get(pvs[n].dbrType,
- pvs[n].reqElems,
+ pvs[n].nElems,
pvs[n].chid,
pvs[n].value);
@@ -253,10 +252,13 @@ static int caget (pv *pvs, int nPvs, RequestT request, OutputT format,
for (n = 0; n < nPvs; n++) {
+ /* Truncate the data printed to what was requested. */
+ if (pvs[n].reqElems != 0 && pvs[n].nElems > pvs[n].reqElems)
+ pvs[n].nElems = pvs[n].reqElems;
switch (format) {
case plain: /* Emulate old caget behaviour */
- if (pvs[n].reqElems <= 1 && fieldSeparator == ' ') printf("%-30s", pvs[n].name);
+ if (pvs[n].nElems <= 1 && fieldSeparator == ' ') printf("%-30s", pvs[n].name);
else printf("%s", pvs[n].name);
printf("%c", fieldSeparator);
case terse:
@@ -270,7 +272,7 @@ static int caget (pv *pvs, int nPvs, RequestT request, OutputT format,
printf("*** no data available (timeout)\n");
else
- if (charArrAsStr && dbr_type_is_CHAR(pvs[n].dbrType) && (reqElems || pvs[n].reqElems > 1)) {
+ if (charArrAsStr && dbr_type_is_CHAR(pvs[n].dbrType) && (reqElems || pvs[n].nElems > 1)) {
dbr_char_t *s = (dbr_char_t*) dbr_value_ptr(pvs[n].value, pvs[n].dbrType);
int dlen = epicsStrnEscapedFromRawSize((char*)s, strlen((char*)s));
char *d = calloc(dlen+1, sizeof(char));
@@ -282,8 +284,8 @@ static int caget (pv *pvs, int nPvs, RequestT request, OutputT format,
fprintf(stderr,"Failed to allocate space for escaped string\n");
} else {
- if (reqElems || pvs[n].nElems > 1) printf("%lu%c", pvs[n].reqElems, fieldSeparator);
- for (i=0; i<pvs[n].reqElems; ++i) {
+ if (reqElems || pvs[n].nElems > 1) printf("%lu%c", pvs[n].nElems, fieldSeparator);
+ for (i=0; i<pvs[n].nElems; ++i) {
if (i) printf ("%c", fieldSeparator);
printf("%s", val2str(pvs[n].value, pvs[n].dbrType, i));
@@ -315,8 +317,8 @@ static int caget (pv *pvs, int nPvs, RequestT request, OutputT format,
else {
printf(" Element count: %lu\n"
" Value: ",
- pvs[n].reqElems);
+ pvs[n].nElems);
@@ -328,7 +330,7 @@ static int caget (pv *pvs, int nPvs, RequestT request, OutputT format,
} else {
diff --git a/src/catools/camonitor.c b/src/catools/camonitor.c
index 82ee20f..8e6b14e 100644
--- a/src/catools/camonitor.c
+++ b/src/catools/camonitor.c
@@ -107,6 +107,7 @@ static void event_handler (evargs args)
if (args.status == ECA_NORMAL)
pv->dbrType = args.type;
+ pv->nElems = args.count;
memcpy(pv->value, args.dbr, dbr_size_n(args.type, args.count));
print_time_val_sts(pv, reqElems);
@@ -150,11 +151,9 @@ static void connection_handler ( struct connection_handler_args args )
ppv->dbrType = DBR_TIME_STRING;
- if (reqElems == 0 || ppv->nElems < reqElems){
- ppv->reqElems = ppv->nElems; /* Use full number of points */
- } else {
- ppv->reqElems = reqElems; /* Limit to specified number */
+ if (reqElems > ppv->nElems)
+ reqElems = ppv->nElems;
+ ppv->reqElems = reqElems;
nConn++;
@@ -163,7 +162,7 @@ static void connection_handler ( struct connection_handler_args args )
/* install monitor once with first connect */
if ( ! ppv->value ) {
- ppv->value = calloc(1, dbr_size_n(ppv->dbrType, ppv->reqElems));
+ ppv->value = calloc(1, dbr_size_n(ppv->dbrType, ppv->nElems));
if ( ppv->value ) {
ppv->status = ca_create_subscription(ppv->dbrType,
ppv->reqElems,
diff --git a/src/catools/tool_lib.c b/src/catools/tool_lib.c
index 0bfcab3..13d6330 100644
--- a/src/catools/tool_lib.c
+++ b/src/catools/tool_lib.c
@@ -455,8 +455,8 @@ char *dbr2str (const void *value, unsigned type)
printf("Failed to allocate for print_time_val_sts\n"); \
} else { \
- if (reqElems || pv->nElems > 1) printf("%c%lu", fieldSeparator, pv->reqElems); \
- for (i=0; i<pv->reqElems; ++i) { \
+ if (reqElems || pv->nElems > 1) printf("%c%lu", fieldSeparator, pv->nElems); \
+ for (i=0; i<pv->nElems; ++i) { \
printf("%c%s", fieldSeparator, val2str(value, TYPE_ENUM, i)); \
@@ -492,7 +492,7 @@ void print_time_val_sts (pv* pv, unsigned long reqElems)
tsInitS = 1;
- if (pv->reqElems <= 1 && fieldSeparator == ' ') printf("%-30s", pv->name);
+ if (pv->nElems <= 1 && fieldSeparator == ' ') printf("%-30s", pv->name);
else printf("%s", pv->name);
if (!pv->onceConnected)
diff --git a/src/catools/tool_lib.h b/src/catools/tool_lib.h
index 5bb6b5d..baebf79 100644
--- a/src/catools/tool_lib.h
+++ b/src/catools/tool_lib.h
@@ -64,8 +64,8 @@ typedef struct
chid chid;
long dbfType;
long dbrType;
- unsigned long nElems;
- unsigned long reqElems;
+ unsigned long nElems; // True length of data in value
+ unsigned long reqElems; // Requested length of data
int status;
void* value;
epicsTimeStamp tsPreviousC;
1.6.6.1
- [PATCH 0/4] Adding dynamic arrays to EPICS Channel Access Michael Abbott
EPICS protocol header Michael Abbott
<2010>
[PATCH 4/4] Drive-by refactoring in caserverio.c Michael Abbott
[Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base Michael Abbott
<2010>
