Kim, Kukhee has proposed merging lp:~khkim/epics-base/alarm-filter into lp:epics-base.
Requested reviews:
EPICS Core Developers (epics-core)
This branch has alarm filter for ai, calc, longin, and mbbi record types.
https://code.launchpad.net/~khkim/epics-base/alarm-filter/+merge/26278
Your team EPICS Core Developers is requested to review the proposed merge of lp:~khkim/epics-base/alarm-filter into lp:epics-base.
=== modified file 'src/rec/aiRecord.c'
--- src/rec/aiRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/aiRecord.c 2010-05-28 09:21:26 +0000
@@ -6,7 +6,7 @@
* EPICS BASE is distributed subject to a Software License Agreement found
* in file LICENSE that is included with this distribution.
-/* $Id$ */
+/* $Id: aiRecord.c,v 1.20.2.6 2009/04/03 14:40:12 lange Exp $ */
/* aiRecord.c - Record Support Routines for Analog Input records */
@@ -41,6 +41,9 @@
#undef GEN_SIZE_OFFSET
#include "epicsExport.h"
+/* Hysterisis for alarm filtering: 1-1/e */
+#define THRESHOLD 0.6321
/* Create RSET - Record Support Entry Table*/
#define report NULL
#define initialize NULL
@@ -99,7 +102,7 @@
extern unsigned int gts_trigger_counter;
-static void checkAlarms(aiRecord *prec);
+static void checkAlarms(aiRecord *prec, epicsTimeStamp *lastTime);
static void convert(aiRecord *prec);
static void monitor(aiRecord *prec);
static long readValue(aiRecord *prec);
@@ -158,12 +161,15 @@
aidset *pdset = (aidset *)(prec->dset);
long status;
unsigned char pact=prec->pact;
+ epicsTimeStamp timeLast;
if( (pdset==NULL) || (pdset->read_ai==NULL) ) {
prec->pact=TRUE;
recGblRecordError(S_dev_missingSup,(void *)prec,"read_ai");
return(S_dev_missingSup);
+ timeLast = prec->time;
status=readValue(prec); /* read the new value */
/* check if device support set pact */
if ( !pact && prec->pact ) return(0);
@@ -174,7 +180,7 @@
else if (status==2) status=0;
/* check for alarms */
- checkAlarms(prec);
+ checkAlarms(prec,&timeLast);
/* check event list */
monitor(prec);
/* process the forward scan link record */
@@ -283,60 +289,114 @@
return(0);
- double val, hyst, lalm;
- double alev;
+ enum {
+ range_Lolo = 1,
+ range_Low,
+ range_Normal,
+ range_High,
+ range_Hihi
+ } alarmRange;
+ static const epicsEnum16 range_stat[] = {
+ SOFT_ALARM, LOLO_ALARM, LOW_ALARM,
+ NO_ALARM, HIGH_ALARM, HIHI_ALARM
+ double val, hyst, lalm, alev, aftc, afvl;
epicsEnum16 asev;
if (prec->udf) {
recGblSetSevr(prec, UDF_ALARM, INVALID_ALARM);
+ prec->afvl = 0;
return;
- val = prec->val;
+ val = prec->val;
hyst = prec->hyst;
lalm = prec->lalm;
- /* alarm condition hihi */
- asev = prec->hhsv;
- alev = prec->hihi;
- if (asev && (val >= alev || ((lalm == alev) && (val >= alev - hyst)))) {
- if (recGblSetSevr(prec, HIHI_ALARM, asev))
- prec->lalm = alev;
- return;
- /* alarm condition lolo */
- asev = prec->llsv;
- alev = prec->lolo;
- if (asev && (val <= alev || ((lalm == alev) && (val <= alev + hyst)))) {
- if (recGblSetSevr(prec, LOLO_ALARM, asev))
- return;
- /* alarm condition high */
- asev = prec->hsv;
- alev = prec->high;
- if (recGblSetSevr(prec, HIGH_ALARM, asev))
- return;
- /* alarm condition low */
- asev = prec->lsv;
- alev = prec->low;
- if (recGblSetSevr(prec, LOW_ALARM, asev))
- return;
- /* we get here only if val is out of alarm by at least hyst */
- prec->lalm = val;
- return;
+ /* check VAL against alarm limits */
+ if ((asev = prec->hhsv) &&
+ (val >= (alev = prec->hihi) ||
+ ((lalm == alev) && (val >= alev - hyst))))
+ alarmRange = range_Hihi;
+ else
+ if ((asev = prec->llsv) &&
+ (val <= (alev = prec->lolo) ||
+ ((lalm == alev) && (val <= alev + hyst))))
+ alarmRange = range_Lolo;
+ else
+ if ((asev = prec->hsv) &&
+ (val >= (alev = prec->high) ||
+ alarmRange = range_High;
+ else
+ if ((asev = prec->lsv) &&
+ (val <= (alev = prec->low) ||
+ alarmRange = range_Low;
+ else {
+ alev = val;
+ asev = NO_ALARM;
+ alarmRange = range_Normal;
+ aftc = prec->aftc;
+ afvl = 0;
+ if (aftc > 0) {
+ /* Apply level filtering */
+ afvl = prec->afvl;
+ if (afvl == 0) {
+ afvl = (double)alarmRange;
+ } else {
+ double t = epicsTimeDiffInSeconds(&prec->time, lastTime);
+ double alpha = aftc / (t + aftc);
+ /* The sign of afvl indicates whether the result should be
+ * rounded up or down. This gives the filter hysteresis.
+ * If afvl > 0 the floor() function rounds to a lower alarm
+ * level, otherwise to a higher.
+ afvl = alpha * afvl +
+ ((afvl > 0) ? (1 - alpha) : (alpha - 1)) * alarmRange;
+ if (afvl - floor(afvl) > THRESHOLD)
+ afvl = -afvl; /* reverse rounding */
+ alarmRange = abs((int)floor(afvl));
+ switch (alarmRange) {
+ case range_Hihi:
+ asev = prec->hhsv;
+ alev = prec->hihi;
+ break;
+ case range_High:
+ asev = prec->hsv;
+ alev = prec->high;
+ break;
+ case range_Normal:
+ asev = NO_ALARM;
+ break;
+ case range_Low:
+ asev = prec->lsv;
+ alev = prec->low;
+ break;
+ case range_Lolo:
+ asev = prec->llsv;
+ alev = prec->lolo;
+ break;
+ prec->afvl = afvl;
+ if (asev) {
+ /* Report alarm condition, store LALM for future HYST calculations */
+ if (recGblSetSevr(prec, range_stat[alarmRange], asev))
+ prec->lalm = alev;
+ } else {
+ /* No alarm condition, reset LALM */
+ prec->lalm = val;
=== modified file 'src/rec/aiRecord.dbd'
--- src/rec/aiRecord.dbd 2005-11-15 23:35:34 +0000
+++ src/rec/aiRecord.dbd 2010-05-28 09:21:26 +0000
@@ -138,6 +138,11 @@
promptgroup(GUI_ALARMS)
interest(1)
+ field(AFTC,DBF_DOUBLE) {
+ prompt("Alarm Filter Time Constant")
+ promptgroup(GUI_ALARMS)
+ interest(1)
field(ADEL,DBF_DOUBLE) {
prompt("Archive Deadband")
promptgroup(GUI_DISPLAY)
@@ -153,6 +158,11 @@
special(SPC_NOMOD)
interest(3)
+ field(AFVL,DBF_DOUBLE) {
+ prompt("Alarm Filter Value")
+ special(SPC_NOMOD)
+ interest(3)
field(ALST,DBF_DOUBLE) {
prompt("Last Value Archived")
special(SPC_NOMOD)
=== modified file 'src/rec/calcRecord.c'
--- src/rec/calcRecord.c 2009-04-03 14:40:13 +0000
+++ src/rec/calcRecord.c 2010-05-28 09:21:26 +0000
@@ -37,6 +37,9 @@
/* Create RSET - Record Support Entry Table */
#define report NULL
@@ -79,7 +82,7 @@
epicsExportAddress(rset, calcRSET);
-static void checkAlarms(calcRecord *prec);
+static void checkAlarms(calcRecord *prec, epicsTimeStamp *timeLast);
static void monitor(calcRecord *prec);
static int fetch_values(calcRecord *prec);
@@ -111,15 +114,19 @@
static long process(calcRecord *prec)
prec->pact = TRUE;
if (fetch_values(prec)==0) {
if (calcPerform(&prec->a, &prec->val, prec->rpcl)) {
recGblSetSevr(prec, CALC_ALARM, INVALID_ALARM);
} else prec->udf = isnan(prec->val);
recGblGetTimeStamp(prec);
+ checkAlarms(prec, &timeLast);
monitor(prec);
@@ -243,14 +250,27 @@
return 0;
- double alev;
+ enum {
+ range_Lolo = 1,
+ range_Low,
+ range_Normal,
+ range_High,
+ range_Hihi
+ } alarmRange;
epicsEnum16 asev;
if (prec->udf) {
+ prec->afvl = 0;
return;
@@ -258,45 +278,89 @@
hyst = prec->hyst;
lalm = prec->lalm;
- return;
- return;
- asev = prec->hsv;
- return;
- asev = prec->lsv;
- alev = prec->low;
- return;
- prec->lalm = val;
- return;
+ else
+ else
+ else
+ else {
+ alev = val;
+ asev = NO_ALARM;
+ afvl = 0;
+ if (aftc > 0) {
+ if (afvl == 0) {
+ } else {
+ double t = epicsTimeDiffInSeconds(&prec->time, timeLast);
+ case range_Hihi:
+ break;
+ case range_High:
+ asev = prec->hsv;
+ break;
+ asev = NO_ALARM;
+ break;
+ case range_Low:
+ asev = prec->lsv;
+ alev = prec->low;
+ break;
+ case range_Lolo:
+ break;
+ if (asev) {
+ } else {
+ prec->lalm = val;
=== modified file 'src/rec/calcRecord.dbd'
--- src/rec/calcRecord.dbd 2007-03-13 16:39:53 +0000
+++ src/rec/calcRecord.dbd 2010-05-28 09:21:26 +0000
@@ -153,6 +153,16 @@
interest(1)
menu(menuAlarmSevr)
+ field(AFTC, DBF_DOUBLE) {
+ interest(1)
+ field(AFVL, DBF_DOUBLE) {
+ interest(3)
field(HYST,DBF_DOUBLE) {
prompt("Alarm Deadband")
=== modified file 'src/rec/longinRecord.c'
--- src/rec/longinRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/longinRecord.c 2010-05-28 09:21:26 +0000
@@ -37,6 +37,8 @@
#define report NULL
@@ -87,7 +89,7 @@
DEVSUPFUN get_ioint_info;
DEVSUPFUN read_longin; /*returns: (-1,0)=>(failure,success)*/
-static void checkAlarms(longinRecord *prec);
+static void checkAlarms(longinRecord *prec, epicsTimeStamp *timeLast);
static void monitor(longinRecord *prec);
static long readValue(longinRecord *prec);
@@ -132,12 +134,14 @@
struct longindset *pdset = (struct longindset *)(prec->dset);
long status;
if( (pdset==NULL) || (pdset->read_longin==NULL) ) {
prec->pact=TRUE;
recGblRecordError(S_dev_missingSup,(void *)prec,"read_longin");
@@ -148,7 +152,7 @@
if (status==0) prec->udf = FALSE;
monitor(prec);
@@ -210,14 +214,28 @@
return(0);
+ enum {
+ range_Lolo = 1,
+ range_Low,
+ range_Normal,
+ range_High,
+ range_Hihi
+ } alarmRange;
+ double aftc, afvl;
epicsInt32 val, hyst, lalm;
epicsInt32 alev;
epicsEnum16 asev;
if (prec->udf) {
+ prec->afvl = 0;
return;
@@ -225,45 +243,88 @@
hyst = prec->hyst;
lalm = prec->lalm;
- return;
- return;
- asev = prec->hsv;
- return;
- asev = prec->lsv;
- alev = prec->low;
- return;
- prec->lalm = val;
- return;
+ else
+ else
+ else
+ else {
+ alev = val;
+ asev = NO_ALARM;
+ afvl = 0;
+ if (aftc > 0) {
+ if (afvl == 0) {
+ } else {
+ case range_Hihi:
+ break;
+ case range_High:
+ asev = prec->hsv;
+ break;
+ asev = NO_ALARM;
+ break;
+ case range_Low:
+ asev = prec->lsv;
+ alev = prec->low;
+ break;
+ case range_Lolo:
+ break;
+ if (asev) {
+ } else {
+ prec->lalm = val;
/* DELTA calculates the absolute difference between its arguments
=== modified file 'src/rec/longinRecord.dbd'
--- src/rec/longinRecord.dbd 2002-07-12 21:35:43 +0000
+++ src/rec/longinRecord.dbd 2010-05-28 09:21:26 +0000
@@ -93,6 +93,16 @@
interest(1)
+ interest(1)
+ interest(3)
field(ADEL,DBF_LONG) {
=== modified file 'src/rec/mbbiRecord.c'
--- src/rec/mbbiRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/mbbiRecord.c 2010-05-28 09:21:26 +0000
@@ -36,6 +36,9 @@
#include "mbbiRecord.h"
#define report NULL
@@ -84,7 +87,7 @@
DEVSUPFUN read_mbbi;/*(0,2)=>(success, success no convert)*/
-static void checkAlarms(mbbiRecord *);
+static void checkAlarms(mbbiRecord *, epicsTimeStamp *);
static void monitor(mbbiRecord *);
static long readValue(mbbiRecord *);
@@ -146,6 +149,7 @@
struct mbbidset *pdset = (struct mbbidset *)(prec->dset);
long status;
if( (pdset==NULL) || (pdset->read_mbbi==NULL) ) {
prec->pact=TRUE;
@@ -153,6 +157,8 @@
@@ -184,7 +190,7 @@
else if(status == 2) status = 0;
monitor(prec);
@@ -274,14 +280,20 @@
return(S_db_badChoice);
-static void checkAlarms(mbbiRecord *prec)
+static void checkAlarms(mbbiRecord *prec, epicsTimeStamp *timeLast)
+ unsigned short alarm;
+ epicsEnum16 asev;
unsigned short *severities;
unsigned short val=prec->val;
/* check for udf alarm */
if(prec->udf == TRUE ){
recGblSetSevr(prec,UDF_ALARM,INVALID_ALARM);
+ prec->afvl = 0;
/* check for state alarm */
@@ -291,8 +303,36 @@
} else {
/* in a state which is an error */
severities = (unsigned short *)&(prec->zrsv);
recGblSetSevr(prec,STATE_ALARM,severities[prec->val]);
+ alarm = severities[prec->val];
+ afvl = 0.;
+ if(aftc > 0.) {
+ if(afvl == 0.) {
+ afvl = (double) alarm;
+ } else {
+ ((afvl>0.)?(1.-alpha):(alpha-1.)) * alarm;
+ if(afvl - floor(afvl) > THRESHOLD)
+ afvl = -afvl;
+ alarm = abs((int)floor(afvl));
+ asev = alarm;
+ recGblSetSevr(prec, STATE_ALARM, asev);
/* check for cos alarm */
if(val == prec->lalm) return;
=== modified file 'src/rec/mbbiRecord.dbd'
--- src/rec/mbbiRecord.dbd 2009-06-08 19:55:49 +0000
+++ src/rec/mbbiRecord.dbd 2010-05-28 09:21:26 +0000
@@ -394,6 +394,16 @@
interest(1)
menu(menuAlarmSevr)
+ interest(1)
+ interest(3)
field(UNSV,DBF_MENU) {
prompt("Unknown State Severity")
promptgroup(GUI_MBB)
- Re: [Merge] lp:~khkim/epics-base/alarm-filter into lp:epics-base Ralph Lange
[Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Dirk Zimoch
<2010>
Re: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Dirk Zimoch
<2010>
