Subject: |
[Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base |
Dirk Zimoch <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 27 May 2010 15:17:25 -0000 |
Dirk Zimoch has proposed merging lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base.
Requested reviews:
EPICS Core Developers (epics-core)
Soft events can be strings now.
Example:
record (event, "$(EVENTREC)") {
field (VAL, "Injection Trigger")
record (ai, "$(OTHERREC)") {
field (EVNT, "Injection Trigger")
record (calcout, "$(CALCREC)") {
field (OEVT, "Injection Trigger")
Discussion:
Do we need hashing of the strings to speed up event triggering? Probably not when we can assume a small number of events and event names that differ early.
https://code.launchpad.net/~dirk.zimoch/epics-base/named-soft-events/+merge/26190
Your team EPICS Core Developers is requested to review the proposed merge of lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base.
=== modified file 'src/db/dbCommon.dbd'
--- src/db/dbCommon.dbd 2009-04-23 20:35:02 +0000
+++ src/db/dbCommon.dbd 2010-05-27 15:17:24 +0000
@@ -43,10 +43,11 @@
special(SPC_SCAN)
interest(1)
- field(EVNT,DBF_SHORT) {
- prompt("Event Number")
+ field(EVNT,DBF_STRING) {
+ prompt("Event Name")
promptgroup(GUI_SCAN)
special(SPC_SCAN)
+ size(40)
interest(1)
field(TSE,DBF_SHORT) {
=== modified file 'src/db/dbIocRegister.c'
--- src/db/dbIocRegister.c 2009-01-16 20:50:40 +0000
+++ src/db/dbIocRegister.c 2010-05-27 15:17:24 +0000
@@ -266,11 +266,11 @@
{ scanppl(args[0].dval);}
/* scanpel */
-static const iocshArg scanpelArg0 = { "event number",iocshArgInt};
+static const iocshArg scanpelArg0 = { "event name",iocshArgString};
static const iocshArg * const scanpelArgs[1] = {&scanpelArg0};
static const iocshFuncDef scanpelFuncDef = {"scanpel",1,scanpelArgs};
static void scanpelCallFunc(const iocshArgBuf *args)
-{ scanpel(args[0].ival);}
+{ scanpel(args[0].sval);}
/* scanpiol */
static const iocshFuncDef scanpiolFuncDef = {"scanpiol",0};
=== modified file 'src/db/dbScan.c'
--- src/db/dbScan.c 2009-04-03 17:46:26 +0000
+++ src/db/dbScan.c 2010-05-27 15:17:24 +0000
@@ -101,12 +101,14 @@
/* EVENT */
-#define MAX_EVENTS 256
typedef struct event_scan_list {
CALLBACK callback;
scan_list scan_list;
+ struct event_scan_list *next;
+ char event_name[MAX_STRING_SIZE];
} event_scan_list;
-static event_scan_list *pevent_list[NUM_CALLBACK_PRIORITIES][MAX_EVENTS];
+static event_scan_list *pevent_list[NUM_CALLBACK_PRIORITIES];
+static epicsMutexId event_list_lock[NUM_CALLBACK_PRIORITIES];
/* IO_EVENT*/
@@ -204,34 +206,46 @@
recGblRecordError(-1, (void *)precord,
"scanAdd detected illegal SCAN value");
} else if (scan == menuScanEvent) {
- int evnt;
+ char* evnt;
int prio;
event_scan_list *pesl;
evnt = precord->evnt;
- if (evnt < 0 || evnt >= MAX_EVENTS) {
- recGblRecordError(S_db_badField, (void *)precord,
- "scanAdd detected illegal EVNT value");
- precord->scan = menuScanPassive;
+ if (*evnt == 0) {
+ recGblRecordError(S_db_badField, (void *)precord,
+ "scanAdd: illegal empty EVNT value");
+ /*precord->scan = menuScanPassive;*/
+ return;
+ if (strlen(evnt) >= MAX_STRING_SIZE) {
+ "scanAdd: too long EVNT value");
return;
prio = precord->prio;
if (prio < 0 || prio >= NUM_CALLBACK_PRIORITIES) {
"scanAdd: illegal prio field");
return;
- pesl = pevent_list[prio][evnt];
+ epicsMutexMustLock(event_list_lock[prio]);
+ for (pesl = pevent_list[prio]; pesl; pesl=pesl->next) {
+ if (strcmp(pesl->event_name, evnt) == 0) break;
if (pesl == NULL) {
pesl = dbCalloc(1, sizeof(event_scan_list));
- pevent_list[prio][evnt] = pesl;
+ strcpy(pesl->event_name, evnt);
pesl->scan_list.lock = epicsMutexMustCreate();
callbackSetCallback(eventCallback, &pesl->callback);
callbackSetPriority(prio, &pesl->callback);
callbackSetUser(pesl, &pesl->callback);
ellInit(&pesl->scan_list.list);
+ pesl->next=pevent_list[prio];
+ pevent_list[prio]=pesl;
+ epicsMutexUnlock(event_list_lock[prio]);
addToList(precord, &pesl->scan_list);
} else if (scan == menuScanI_O_Intr) {
io_scan_list *piosl = NULL;
@@ -287,31 +301,25 @@
"scanDelete detected illegal SCAN value");
- int evnt;
+ char* evnt;
int prio;
scan_list *psl = 0;
- return;
- "scanAdd: illegal prio field");
+ "scanDelete detected illegal PRIO field");
return;
- if (pesl) psl = &pesl->scan_list;
- if (!pesl || !psl)
- recGblRecordError(-1, (void *)precord,
- "scanDelete for bad evnt");
- else
+ pesl = pevent_list[prio];
+ for (; pesl; pesl=pesl->next) {
+ if (pesl && (psl = &pesl->scan_list))
deleteFromList(precord, psl);
io_scan_list *piosl=NULL;
@@ -372,21 +380,22 @@
return 0;
-int scanpel(int event_number) /* print event list */
+int scanpel(char* evnt) /* print event list */
char message[80];
- int prio, evnt;
+ int prio;
- for (evnt = 0; evnt < MAX_EVENTS; evnt++) {
- if (event_number && evnt<event_number) continue;
- if (event_number && evnt>event_number) break;
- for (prio = 0; prio < NUM_CALLBACK_PRIORITIES; prio++) {
- if (!pesl) continue;
- if (ellCount(&pesl->scan_list.list) == 0) continue;
- sprintf(message, "Event %d Priority %s", evnt, priorityName[prio]);
- printList(&pesl->scan_list, message);
+ for (prio = 0; prio < NUM_CALLBACK_PRIORITIES; prio++) {
+ for (; pesl; pesl = pesl->next) {
+ if (!evnt || strcmp(pesl->event_name, evnt) == 0) {
+ if (ellCount(&pesl->scan_list.list) == 0) continue;
+ sprintf(message, "Event \"%s\" Priority %s", pesl->event_name, priorityName[prio]);
+ printList(&pesl->scan_list, message);
return 0;
@@ -420,31 +429,40 @@
static void initEvent(void)
- int evnt, prio;
+ int prio;
- pevent_list[prio][evnt] = NULL;
+ pevent_list[prio] = NULL;
+ event_list_lock[prio] = epicsMutexMustCreate();
+void post_named_event(char* evnt)
+ int prio;
+ event_scan_list *pesl;
+ if (scanCtl != ctlRun) return;
+ if (!evnt || *evnt == 0) return;
+ for (prio=0; prio<NUM_CALLBACK_PRIORITIES; prio++) {
+ if (strcmp(pesl->event_name, evnt) == 0) {
+ if (ellCount(&pesl->scan_list.list) >0)
+ callbackRequest((void *)pesl);
void post_event(int event)
- int prio;
- event_scan_list *pesl;
- if (scanCtl != ctlRun) return;
- if (event < 0 || event >= MAX_EVENTS) {
- errMessage(-1, "illegal event passed to post_event");
- return;
- for (prio=0; prio<NUM_CALLBACK_PRIORITIES; prio++) {
- pesl = pevent_list[prio][event];
- if (ellCount(&pesl->scan_list.list) >0)
- callbackRequest((void *)pesl);
+ char event_name[10];
+ sprintf(event_name, "%i", event);
+ post_named_event(event_name);
void scanIoInit(IOSCANPVT *ppioscanpvt)
=== modified file 'src/db/dbScan.h'
--- src/db/dbScan.h 2009-04-02 14:11:27 +0000
+++ src/db/dbScan.h 2010-05-27 15:17:24 +0000
@@ -32,6 +32,11 @@
#define MAX_PHASE SHRT_MAX
#define MIN_PHASE SHRT_MIN
+#ifndef __GNUC__
+#define __attribute(dummy)
+#endif
/*definitions for I/O Interrupt Scanning */
struct io_scan_list;
@@ -43,7 +48,9 @@
epicsShareFunc void scanRun(void);
epicsShareFunc void scanPause(void);
-epicsShareFunc void post_event(int event);
+epicsShareFunc void post_event(int event) __attribute__ ((deprecated))
+ __attribute__ ((warning ("use post_named_event instead")));
+epicsShareFunc void post_named_event(char* event);
epicsShareFunc void scanAdd(struct dbCommon *);
epicsShareFunc void scanDelete(struct dbCommon *);
epicsShareFunc double scanPeriod(int scan);
@@ -54,7 +61,7 @@
epicsShareFunc int scanppl(double rate);
/*print event lists*/
-epicsShareFunc int scanpel(int event_number);
+epicsShareFunc int scanpel(char *event_name);
/*print io_event list*/
epicsShareFunc int scanpiol(void);
=== modified file 'src/dev/softDev/devEventSoft.c'
--- src/dev/softDev/devEventSoft.c 2008-08-06 22:11:51 +0000
+++ src/dev/softDev/devEventSoft.c 2010-05-27 15:17:24 +0000
@@ -51,7 +51,7 @@
/* INP must be CONSTANT, PV_LINK, DB_LINK or CA_LINK*/
switch (prec->inp.type) {
case CONSTANT:
- if (recGblInitConstantLink(&prec->inp, DBF_USHORT, &prec->val))
+ if (recGblInitConstantLink(&prec->inp, DBF_STRING, &prec->val))
prec->udf = FALSE;
break;
case PV_LINK:
@@ -70,7 +70,7 @@
long status;
- status = dbGetLink(&prec->inp, DBR_USHORT, &prec->val, 0, 0);
+ status = dbGetLink(&prec->inp, DBR_STRING, prec->val, 0, 0);
if (!status) {
prec->udf = FALSE;
if (prec->tsel.type == CONSTANT &&
=== modified file 'src/rec/calcoutRecord.c'
--- src/rec/calcoutRecord.c 2010-04-05 18:49:18 +0000
+++ src/rec/calcoutRecord.c 2010-05-27 15:17:24 +0000
@@ -539,27 +539,21 @@
if (prec->nsev < INVALID_ALARM ) {
/* Output the value */
status = writeValue(prec);
- /* post event if output event != 0 */
- if (prec->oevt > 0) {
- post_event((int)prec->oevt);
+ /* post output event if set */
+ post_named_event(prec->oevt);
} else switch (prec->ivoa) {
case menuIvoaContinue_normally:
break;
case menuIvoaDon_t_drive_outputs:
break;
case menuIvoaSet_output_to_IVOV:
prec->oval = prec->ivov;
break;
default:
status = -1;
=== modified file 'src/rec/calcoutRecord.dbd'
--- src/rec/calcoutRecord.dbd 2009-04-04 23:01:23 +0000
+++ src/rec/calcoutRecord.dbd 2010-05-27 15:17:24 +0000
@@ -255,10 +255,11 @@
prompt("OCAL Valid")
interest(1)
- field(OEVT,DBF_USHORT) {
+ field(OEVT,DBF_STRING) {
prompt("Event To Issue")
promptgroup(GUI_CLOCK)
asl(ASL0)
+ size(40)
field(IVOA,DBF_MENU) {
prompt("INVALID output action")
=== modified file 'src/rec/eventRecord.c'
--- src/rec/eventRecord.c 2009-07-08 18:14:11 +0000
+++ src/rec/eventRecord.c 2010-05-27 15:17:24 +0000
@@ -103,7 +103,7 @@
if (prec->siol.type == CONSTANT) {
- recGblInitConstantLink(&prec->siol,DBF_USHORT,&prec->sval);
+ recGblInitConstantLink(&prec->siol,DBF_STRING,&prec->sval);
if( (pdset=(struct eventdset *)(prec->dset)) && (pdset->init_record) )
@@ -123,7 +123,7 @@
if ( !pact && prec->pact ) return(0);
prec->pact = TRUE;
- if(prec->val>0) post_event((int)prec->val);
+ post_named_event(prec->val);
recGblGetTimeStamp(prec);
@@ -140,7 +140,7 @@
static long get_value(eventRecord *prec, struct valueDes *pvdes)
- pvdes->field_type = DBF_USHORT;
+ pvdes->field_type = DBF_STRING;
pvdes->no_elements=1;
pvdes->pvalue = (void *)(&prec->val);
return(0);
@@ -177,10 +177,10 @@
return(status);
if (prec->simm == menuYesNoYES){
- status=dbGetLink(&(prec->siol),DBR_USHORT,
+ status=dbGetLink(&(prec->siol),DBR_STRING,
&(prec->sval),0,0);
if (status==0) {
- prec->val=prec->sval;
+ strcpy(prec->val, prec->sval);
prec->udf=FALSE;
} else {
=== modified file 'src/rec/eventRecord.dbd'
--- src/rec/eventRecord.dbd 2002-07-12 21:35:43 +0000
+++ src/rec/eventRecord.dbd 2010-05-27 15:17:24 +0000
@@ -9,10 +9,11 @@
recordtype(event) {
include "dbCommon.dbd"
- field(VAL,DBF_USHORT) {
- prompt("Event Number To Post")
+ field(VAL,DBF_STRING) {
+ prompt("Event Name To Post")
promptgroup(GUI_INPUTS)
asl(ASL0)
+ size(40)
field(INP,DBF_INLINK) {
prompt("Input Specification")
@@ -24,8 +25,9 @@
interest(1)
- field(SVAL,DBF_USHORT) {
+ field(SVAL,DBF_STRING) {
prompt("Simulation Value")
+ size(40)
field(SIML,DBF_INLINK) {
prompt("Sim Mode Location")
- Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Babak Kalantari
- Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Ralph Lange
- Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Dirk Zimoch
- Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Andrew Johnson
[Merge] lp:~dirk.zimoch/epics-base/non-val-attributes into lp:epics-base Dirk Zimoch
[Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Dirk Zimoch
<2010>
Re: [Merge] lp:~dirk.zimoch/epics-base/non-val-attributes into lp:epics-base Dirk Zimoch
<2010>
