Subject: |
Re: [Merge] lp:~ronaldo-mercado/epics-base/capr into lp:epics-base |
Ralph Lange <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 26 May 2010 15:53:28 -0000 |
Here's what I noticed:
* All EPICS Base environment variables start with 'EPICS_' - please use that prefix on the name of the env var that defines the DBD.
* Lines 104/106 of the code seem to do the same thing?!
* I was confused by seeing all these "ezca..." strings in code that (luckily) does not use ezca. But they obviously are only used internally.
* The error message in case <pv>.RTYP is not found should be a bit more explanatory. If you run the tool against a CAS based server (e.g. excas), it says "Record "fred" not found". Well, the PV "fred" does indeed exist, it's just not an EPICS record.
* Please consistently use single or double quotes around channel names in printed messages.
https://code.launchpad.net/~ronaldo-mercado/epics-base/capr/+merge/26037
Your team EPICS Core Developers is requested to review the proposed merge of lp:~ronaldo-mercado/epics-base/capr into lp:epics-base.
- [Merge] lp:~ronaldo-mercado/epics-base/capr into lp:epics-base Ronaldo Mercado
Re: [Merge] lp:~khkim/epics-base/fix-timestamp into lp:epics-base Ralph Lange
Re: [Merge] lp:~ronaldo-mercado/epics-base/capr into lp:epics-base Andrew Johnson
<2010>
<2010>
