2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [Question #110395]: push fails?
To: [email protected]
Cc: EPICS Core Talk <[email protected]>
Date: Mon, 10 May 2010 09:15:27 -0400
Hi Jeff,
as with all VCS I know, access using http transport is read-only.
You will have to use ssh transport to push changes.
Hope this helps,
Ralph
On Mon 10 May 2010 1:18:25 Jeff Hill wrote:
New question #110395 on EPICS Base:
https://answers.launchpad.net/epics-base/+question/110395
I dont know if this is normal but will have to discard the work I did this weekend because a push failed.
Run command: bzr push --directory C:/epicsInBazaar/cvs-trunk/trunk --no-strict
Using saved push location: http://bazaar.launchpad.net/~epics-core/epics-base/cvs-trunk/
bzr: ERROR: Cannot lock LockDir(http://bazaar.launchpad.net/~epics-core/epics-base/cvs-trunk/.bzr/branch/lock): Transport operation not possible: http does not support mkdir()
[Question #110395]: push fails? Jeff Hill
Prev: [Question #110395]: push fails? Jeff Hill
Next: RE: Bug in macLib Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: [Merge] lp:~ralph-lange/epics-base/ca-over-tcp into lp:epics-base Jeff Hill
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
