It looks like I underestimated the scope of the problem. It looks like
none of the previous value fields (MLST, ALST, LALM, OVAL, ORBV, ...)
get initialized for any recordtype. Given how uniform this appears I
have to ask: is this a feature? I think the answer should be no.
I encountered this problem using streamdevice with a serial device
(sr725). It has non-volatile memory for settings, so I want my output
records to initially read the current value. The obvious way to was to
use '@init' which happens before the record is processed (I think).
Unless the current behavior changes the only way this can work is if I
mark all settings PINI=YES and hope there are no side effects to
re-setting a parameter.
This seems like an obvious problem, so I can't help but think that I
must be missing something here...
Michael
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Wednesday, March 24, 2010 2:28 PM
> To: [email protected]
> Cc: Davidsaver, Michael
> Subject: Re: missing monitors from boRecord (patch)
> On Wednesday 24 March 2010 13:05:00 Davidsaver, Michael wrote:
> > A one line fix. This patch will apply against <3.14.11. For
> >=3.14.11
> > change pbo to prec.
> Applied with prec modification to the 3.14 branch, thanks.
> - Andrew
> The best FOSS code is written to be read by other humans -- Harald
> Welte
- RE: missing monitors Davidsaver, Michael
- missing monitors from boRecord Davidsaver, Michael
- RE: missing monitors from boRecord (patch) Davidsaver, Michael
- Re: missing monitors from boRecord (patch) Andrew Johnson
Re: [Bug 541396] Re: initialize VAL of an mbbi/o record with a string Benjamin Franksen
<2010>
<2010>
