2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: why doesnt the include file install set the file permisions to unwritable?
To: Jeff Hill <[email protected]>
Cc: "'Core-Talk'" <[email protected]>, [email protected]
Date: Thu, 19 Nov 2009 08:12:45 -0600
All files in the<base>/ include directory on my OS X machine are mode 644, as they should be.
Are you sure that what you're seeing isn't just the way that you've got your UMASK environment variable set?
On Nov 18, 2009, at 5:22 PM, Jeff Hill wrote:
All,
It appears that, both on Unix and Windows, the header files have their
permissions set to writeable after being installed into the include
directories. When I am in the IDE working away I sometimes inadvertently
double click on a compiler error message and end up
auto-opening-for-editing, and eventually modifying, an installed include file. It can definitely be very confusing if one modifies the installed include file, and not the source for the installed include file. I try to keep my guard up against this issue, but seem to keep repeating the same
mistake.
So, given this perspective and some others, it appears to be sensible for all include files to have their permissions set to un-writable when they are installed, but maybe there is some practical issue that prevents this from
being standard behavior that I don’t see?
Your thoughts?
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Re: why doesnt the include file install set the file permisions to unwritable? Andrew Johnson
why doesnt the include file install set the file permisions to unwritable? Jeff Hill
Prev: why doesnt the include file install set the file permisions to unwritable? Jeff Hill
Next: Re: why doesnt the include file install set the file permisions to unwritable? Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
