2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: main trunk base build failure win32-x86
To: <[email protected]>
Date: Tue, 1 Sep 2009 08:49:40 -0600
For what it's worth, base builds have been failing for the last few months
on the main trunk, when targeting win32-x86. The failure occurs when
dbToMenu runs.
	ntdll.dll!7764f897()
 	[Frames below may be incorrect and/or missing, no symbols loaded for
ntdll.dll]
 	ntdll.dll!7764f26c()
 	kernel32.dll!75e83621()
>	msvcr90.dll!free(void * pBlock=0x027b2388)  Line 110	C
 	dbStaticHost.dll!_dbCatString@16()  + 0xa4 bytes	C
 	dbToMenuH.exe!_main()  + 0xce bytes	C
 	dbToMenuH.exe!__tmainCRTStartup()  Line 586 + 0x17 bytes	C
 	kernel32.dll!75e8e4a5()
 	ntdll.dll!7769cfed()
 	ntdll.dll!7769d1ff()
The problem may have to do with freeing a string from a different dll than
the one that allocated it.
	newString = dbCalloc(size,sizeof(char));
	if(*string) {
	    strcpy(newString,*string);
	    free((void *)(*string));
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
Re: main trunk base build failure win32-x86 Andrew Johnson
Prev: Re: CVS trunk compiles Andrew Johnson
Next: RE: About the reference counting in GDD smart pointer Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: main trunk base build failure win32-x86 Andrew Johnson
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
