Hi Steve,
Stephen Lewis wrote:
I consider forwarding a ca_put from a client into a ca_put-notify a
design flaw: behavior would be very different between a local IOC on
the client LAN and a distant IOC behind a gateway.
Correct.
Keep in mind, though, that until Jeff's very recent patch to PCAS the GW
simply couldn't distinguish between a client doing a ca_put and a client
doing a ca_put_notify.
In that situation, forwarding a simple ca_put as an acknowledged
ca_put_notify is definitely better than forwarding a ca_put_notify as a
fire-and-forget ca_put, faking the acknowledgment. So, from the two
possible options which were both wrong, the gateway was using the better.
Caching/no-caching:
Among the GW's objectives are keeping load off the IOCs and acting
transparently. With certain aspects of Channel Access, e.g. answering
get requests, forwarding IOC-side beacons to the clients, and forwarding
client side name-resolution-requests to the IOCs, these two objectives
are contrary. If the GW acts 100% transparent, it does not offload the
IOCs (in some cases, it would even put more load onto the IOCs). If the
GW tries to shield the IOCs, it will not be able to act completely
transparent. While the original approach was trying to implement a
reasonable compromise, the direction that Dirk is pursuing is certainly
the right one: when the level of compromise is made configurable for
these aspects, the user can select the appropriate behavior for each GW
instance.
Cheers,
Ralph
- Re: GW status Ernest L. Williams Jr.
- RE: GW status Jeff Hill
- Re: GW status Stephen Lewis
Re: GW status Dirk Zimoch
<2009>
<2009>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
