I consider forwarding a ca_put from a client into a ca_put-notify a
design flaw: behavior would be very different between a local IOC on
the client LAN and a distant IOC behind a gateway.
Fundamentally EPICS is asynchronous and all client applications should
have been and should be written strictly to this assumption when using
ca_put. As I recall, ca_put_notify was added to allow sophisticated
client to build up a type of 'transaction' capability.
In the case of the motor record (the case that triggered all this
investigation), when the monitor on the DMOV field goes 0->1 then you
can trust all the other field values. Everyone up to now must have
known this, otherwise all the instances where there is no gateway
would have given poor results.
On 4 Aug, 2009, at 3:11 PM, Jeff Hill wrote:
1. PCAS was unable (before the patch) to handle subscriptions
during
the time that ca_put_callback was being processed.
- Re: GW status Ralph Lange
- RE: GW status Jeff Hill
Re: GW status Dirk Zimoch
<2009>
<2009>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
