(I'm very sorry that quoting is messed up below. Unfortunately I'm still stuck with Outlook for e-mail from work, which seems to deliberately break all mailing conventions. I'll try a different mailer next time.)
> On Thursday 30 July 2009 06:02:50 Abbott, MG (Michael) wrote:
> > This patch is rather important. The line removed by this
> patch has a
> > very strange effect: it adds makefile rules of the form
> > $(action).$(arch): $(action).$(EPICS_HOST_ARCH)
> > specifically, it adds the rule
> > install.linux-arm: install.linux-x86
> > to my build.
> This rule was added because when using the -j option to
> enable parallel builds
> we have to make sure that any host programs have finished
> compiling before we
> can start compiling objects for the targets, since we might
> have to run those
> host programs when building the target code. Unfortunately
> in the current
> versions of GNUmake it is not possible to detect that the -j
> option has been
> supplied (unlike most other make options which *can* be
> detected). If we
> could detect the -j option we would be able to make that rule
> conditional,
> but we can't. Even if we could though, your application
> wouldn't be able to
> take advantage of the make -j option, so this isn't really be
> a proper
> solution anyway.
> > The effect of this rule is that in order to build my
> > linux-arm IOC, I have to first build a linux-x86 version of
> the IOC, and
> > more generally, all cross-compiled IOCs depend on having a
> native IOC
> > build succeed first. This isn't going to work.
> Each EPICS architecture declares whether it can build Host or
> Ioc targets or
> both by setting VALID_BUILDS in its
> base/configure/CONFIG.Common.<arch> file.
> Host targets are those named in the Makefile variables
> PROD_HOST and similar,
> while Ioc targets are those named in in PROD_IOC etc.
> You can limit what gets built for specific OS classes by
> using PROD_IOC_Linux,
> but that doesn't help you since both your host and target are
> in that same OS
> class.
> If your application can't be built on linux-x86 then one
> solution would be to
> create a new linux-x86-host architecture which defines
> VALID_BUILDS=Host
> only, and use that for hosting cross-builds for your
> linux-arm applications.
> However if it's only a few applications it will be much
> simpler to override
> VALID_BUILDS in those applications; in each one you would
> create a new file
> configure/CONFIG_SITE.Common.linux-x86 that sets
> VALID_BUILDS=Host and hence
> stops the build system from trying to build any Ioc code on
> linux-x86 inside
> that application.
> You will of course need to make sure that your Makefiles
> properly set the
> PROD_IOC and LIBRARY_IOC variables rather than PROD and
> LIBRARY. You can
> still build linux-x86 code if needed by using PROD or
> PROD_HOST instead.
> This change will also mean that you no longer have specify
> 'make linux-arm'
> every time (which I guess is what you've been doing), you can just
> run 'make'.
Well.
Actually, I just use `make` to build, but I specify my list of valid BUILD_ARCH targets in configure/CONFIG.
Sorry, just going on holiday for a week, so don't have time to respond properly to your solution.
Have to say I don't like it, think you've broken the make system. Not being able to specify target builds is really not clever, and at first glance your workarounds sound very cumbersome -- but I'll have a proper look week after next. Do you have time to look at my build: http://controls.diamond.ac.uk/downloads/libera ? I've tried to make the configure and Makefiles as clear and simple as I can, but the EPICS build is always full of mysteries for me.
> > Patching CONFIG.Common.linux-arm. This patch is arguable,
> but I'm not
> > sure that such target specific architecture flags belong in
> EPICS base.
> > The line removed by this patch crept into 3.14.10, and
> breaks the Libera
> > build.
> This change was contributed by Heinrich du Toit who is no
> longer working with
> EPICS anyway. I have reverted it.
> Thanks for testing this.
> - Andrew
> The best FOSS code is written to be read by other humans --
> Harold Welte
Sorry about the nonsense below. Think I'll mail from home next time.
Scanned by iCritical.
- Re: Base R3.14.11-pre1 available for testing Andrew Johnson
<2009>
<2009>
