2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: epicsSnPrintf is very slow when converting string arrays in GDD's aitConvert.cc
To: Jeff Hill <[email protected]>
Cc: "'Amedeo Perazzo'" <[email protected]>, "'Core-Talk'" <[email protected]>, "'Dirk Zimoch'" <[email protected]>, "Zhou, Jingchen" <[email protected]>, "Ernest L. Williams Jr." <[email protected]>
Date: Thu, 23 Jul 2009 12:58:33 -0700
Hi Jeff,
Here is an example of some the large arrays we have running around at SLAC --LCLS:
FEE system
DIAG:FEE1:481:DISPLAYWF.NELM 262144 DIAG:FEE1:482:DISPLAYWF.NELM 262144 CAMR:FEE1:455:IMAGE.NELM 307200 E- system ---------------
YAGS:DMP1:500:IMAGE.NELM       1.44768e+06
CAMR:IN20:186:IMAGE.NELM       307200
By the way, why don't we suffer from these issues with the IOC core implementation of the CA Server (i.e. rsrv)?
Or maybe, there are some subtle issues with large arrays even for iocCore?
One of the work-arounds we are considering for the purposes of IOC-Load balancing is to use a softIOC
in front of the source IOC.  Then most of our CA clients would make a connection to the softIOC
for a subscription to large arrays such as camera images.
What do you think?
Ernest
Jeff Hill wrote:
Ø 0.000132 seconds per conversion - is epicsSnPrintf() really that slow?
To answer my own question; no. I just finished adding cvtFastPerform.cpp to libCom/tests and it looks like double to string conversion take more like 3 uSec worst case which is about 44 times faster than calculated.
Nevertheless, I am curious. What is the largest array size being communicated via the gateways at SLAC and at PSI? This might become a big issue for arrays exceeding say one million elements (that are converted to strings by the gateway).
Still bug hunting.
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected] <mailto:[email protected]>
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
*Sent:* Wednesday, July 22, 2009 6:13 PM
*To:* 'Dirk Zimoch'; 'Ralph Lange'; 'Ernest L. Williams Jr.'; 'Amedeo Perazzo'
*Cc:* 'Core-Talk'
*Subject:* epicsSnPrintf is very slow when converting string arrays in GDD's aitConvert.cc
All,
I have discovered that a PCAS hang can occur when clients are fetching very large arrays as strings. Just to convert the number of elements that fit in a very large EPICS_CA_MAX_ARRAY_SIZE buffer with epicsSnPrintf can take a very long time. It appears that this required about 33 seconds during testing with EPICS_CA_MAX_ARRAY_SIZE of 10,000,000. Based on that I calculate 33 / ( 10,000,000 / MAX_STRING_SIZE ) is 0.000132 seconds per conversion. Is epicsSnPrintf() really that slow?
The solution appears to be to use the cvtFast library where it is in range in GDD’s aitConvert.cc. The cvtFast functions are a bit scary in today’s world - because a buffer size isn’t passed in – BTW. The current workaround is to just not use them for buffer sizes below some threshold.
Jeff
RE: epicsSnPrintf is very slow when converting string arrays in GDD's aitConvert.cc Jeff Hill
Prev: RE: epicsSnPrintf is very slow when converting string arrays in GDD's aitConvert.cc Jeff Hill
Next: RE: epicsSnPrintf is very slow when converting string arrays in GDD's aitConvert.cc Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
