2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Patch: Move alarm.h and rename alarmString.h
To: <[email protected]>
Date: Fri, 26 Jun 2009 14:10:26 -0400
> -----Original Message-----
> From: [email protected] [mailto:core-talk-
> [email protected]] On Behalf Of Andrew Johnson
> Sent: Friday, June 12, 2009 6:52 PM
> To: Core-Talk
> Subject: Patch: Move alarm.h and rename alarmString.h
> Michael Davidsaver suggests we make the changes in the attached patch,
> which moves alarm.h from src/dbStatic to src/ca and puts the static
> alarm strings into libca.
> We've never really got the alarm enums right; there are equivalent
> definitions in src/db/menuAlarmStat.dbd which must match alarm.h, and
> we currently have the header alarmString.h which currently instantiates
> a global alarm string array into whatever file it's included by.  This
> is used both internally (by catools and cap5) and externally (by MEDM,
> ALH, etc).
> Unfortunately there are more alarm status string values than can be
> transported by CA as a DBF_ENUM, and even if they could be this
> wouldn't help very much given that the extended dbr_ types include a
> stat field anyway.
> I have made some (not terribly satisfactory) changes in this area since
> R3.14.10 but Michael's idea of putting the strings into libca seems
> interesting.
> Please discuss...
> - Andrew
> The best FOSS code is written to be read by other humans -- Harold
> Welte
A slight change w/ respect to the previous patch.  To prevent compilation problem with external tools an empty 'alarmString.h' is created in src/ca/, and defining epicsAlarmGLOBAL is not an error.  Both ALH (1.2.23) and MEDM (3.1.4) compile and run without modification.
Michael
Attachment: 0001-move-alarm.h-and-rename-alarmString.h.patch
Description: 0001-move-alarm.h-and-rename-alarmString.h.patch
RE: Patch: Move alarm.h and rename alarmString.h Jeff Hill
Patch: Move alarm.h and rename alarmString.h Andrew Johnson
Prev: Patch: Move alarm.h and rename alarmString.h Andrew Johnson
Next: RE: Patch: Move alarm.h and rename alarmString.h Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
