2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Faster re-connect for CA clients
To: "'Stephen Lewis'" <[email protected]>
Cc: "'Core-Talk'" <[email protected]>
Date: Mon, 1 Jun 2009 12:47:23 -0600
Ø  Reconnects sometimes take several minutes
How many PVs are in this client? Does the client see the servers beacons? Was the IOC either rebooted or reconnected to the network when this happened (i.e. should the client lib have detected a beacon anomaly)?
There have been some discussions about this recently so it’s probably a good idea to document the gory details to core-talk.
A difference in behavior in R3.14 compared to the EPICS you have used in the past is that unresolved PVs still get a search rate boost when there is a beacon anomaly, but its magnitude is smaller (a smaller rate increase,  a longer period, than in the past). In previous versions a beacon anomaly caused a boost all the way up to the new channel search rate. In current versions the PV gets a boost up to a (typically 5.0 second) search rate. So, depending the number of channels you can connect per second in a beacon anomaly scenario depends on several things.
O depending on the size of channel names you get more or less search requests in a udp frame. We will call this number N.
O the ca client maintains a private estimate of the number of udp search frames it can send all together at a particular instant in time w/o swamping the buffering capacity of the {client, network, aggregate of all server spoken to} system. We will call this M.
O the ca client maintains a private estimate of the round trip time based on an aggregate of all servers successfully conversed with over UDP. If this estimate is what we see  for typical LAN interactions then beacon anomaly search period is 5.0 seconds. Otherwise its set at 2**O times the round trip estimate where O is number computed currently something like this. The beaconAnomalySearchPeriod constant is currently 5.0 seconds. We will call this the effective beacon anomaly search period, or P.
I = log ( beaconAnomalySearchPeriod / minRoundTripEstimate ) / log ( 2.0 )
P = (2**I) * (roundTripEstimate)
Therefore you can connect at best N requests per frame times M frames per try divided by P tries per second – in a beacon anomaly reconnect scenario. This is assuming that servers respond on the first try. If they don’t then it means congestion and we are better off waiting longer.
1.     Should I set EPICS_CA_BEACON_PERIOD and EPICS_CAS_BEACON_PERIOD to be the same?  (5 sec)
There is a bug in the doc. It should state that EPICS_CA_BEACON_PERIOD is the default for EPICS_CAS_BEACON_PERIOD. I just finished fixing this problem.
Short answer. The beacon period is purely a server configuration. It looks first for EPICS_CAS_BEACON_PERIOD. If it doesn’t find that it looks for EPICS_CA_BEACON_PERIOD. You need only set EPICS_CAS_BEACON_PERIOD.
Long story. We have to keep EPICS_CA_BEACON_PERIOD for backwards compatibility. In the GW we have to keep certain aspects of client configuration separate from server configuration. We needed therefore _CAS_ versions of certain variables. Ralph asked later for EPICS_CAS_BEACON_PERIOD so that names are consistent.
2.     Can I set EPICS_CA_CONN_TMO to 10 if the above are 5, or should I use >10?
I have always said it should be at least twice as long. If you set it to be exactly twice then maybe once in awhile the client lib will not see a beacon and the consequently send a message to the IOC to see if it’s still responsive, but that’s not going to be a serious network bandwidth consumption issue - I suspect. If you set it to be four times as long then maybe the EPICS system will be slightly less likely to mark circuits as unresponsive when there is some congestion. So you have some freedom to tune your system.
3. What exactly does EPICS_CA_MAX_SEARCH do?  Does it tell clients to finally give up broadcasting until at least one beacon anomaly or new beacon is detected?
In any recent version of R3.14 the CA client never stops searching for undefined PVs. The EPICS_CA_MAX_SEARCH_PERIOD variable determines the upper limit for the exponential back-off of the udp search rate.
Jeff
Sent: Monday, June 01, 2009 11:02 AM
To: Jeff Hill
Subject: Re: Faster re-connect for CA clients
Reconnects sometimes take several minutes.  I am the EPICS system manager: so I am trying to set both client and server EPICS_CA values consistently.  So my questions are:
On 1 Jun, 2009, at 8:52 AM, Jeff Hill wrote:
Hi Steve,
If CA is working correctly the client should be reconnecting promptly if it sees the server’s beacon change. How long does it take to reconnect there?
The beacon period should be less than half of the connection timeout, but the beacon period is typically set by the EPICS system manager(s).
Jeff
Sent: Friday, May 29, 2009 6:27 PM
To: Jeff Hill
Subject: Faster re-connect for CA clients
Jeff--
We talked at Vancouver about a new CA environment variable to shorten the time it takes a CA client to re-connect; was it: EPICS_CA_MAX_SEARCH_PERIOD?  I was going to set it to 60 seconds.  I now have EPICS_CA_CONN_TMO=10 secs and EPICS_CA_BEACON_PERIOD=5 secs.  Should I also set EPICS_CAS_BEACON_PERIOD=5 secs?
--Steve
Prev: How to use process variable z abdou
Next: Patch: Move alarm.h and rename alarmString.h Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
