2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: some field definitions
To: Tim Mooney <[email protected]>
Cc: Core-Talk <[email protected]>, "Dalesio, Leo" <[email protected]>
Date: Mon, 27 Apr 2009 11:28:56 -0500
Hi Tim,
Thanks for thinking about this.
On Monday 27 April 2009 01:50:52 Tim Mooney wrote:
> I think PUTF is for EPICS to keep track of whether a record was processed
> by a CA client, or by a PP link.  EPICS uses this to decide whether break
> a loop in a lockset (a PP link trying to process a record that's already
> executing as the result of a PP link) or allow two independent actors to
> process a record at overlapping times (accidental collision between a PP
> link and a CA put).
The IOC can't distinguish between regular CA clients and CA links from itself
or another IOC, and I don't see why it would want/need to do so.  I *can* see
it being useful for a record to be able to distinguish between processing
caused by any kind of put and processing where no record field has been
changed since last time -- if PUTF is false, it doesn't need to check if any
of its configuration fields changed at all.
I don't think breaking loops can be the reason, since any loop you make with
output links can also be made with input or forward links and PUTF is not
examined at all in those cases.  Loops are broken using the rule that PACT of
a record containing DB links must be TRUE whenever another record is being
processed through any of those links.  This is enforced in dbScanLink()
[which is called by dbPutLinkValue()] and in dbGetLinkValue().  This doesn't
break a loop between two async records (which is where the RPRO field is
needed), but that's a documented situation that we can't easily detect.
> I'm not sure about your item 4, but I don't think a
> database link should ever result in PUTF being set.  Also, I think
> recGblFwdLink should clear PUTF always. If RPRO and PUTF are both set,
> it means a record was processing because of a CA put, and a PP link tried
> to process it, so the processing motivated by RPRO must be PP-link
> processing.
The fact that we can't understand item 4 is why I think this is a historical
artifact.  With the change I proposed, PUTF tells the record whether any of
its fields have been modified since it was last processed, which I maintain
is useful information.  Currently the *only* place we actually look at the
value of PUTF is in dbPutLinkValue(), as described in my item 4.
Why would a record want or need to distinguish between being processed as the
target of a DB vs a CA link or other CA client?  Assuming that PUTF isn't
required for reasons internal to dbAccess (which I think is the case), what
would you *like* PUTF to mean?  We could even make PUTF and/or RPRO into
counters so you could tell how many fields were changed while your PACT field
was marking you as busy (although we'd only reprocess it once).
- Andrew
> Andrew Johnson wrote:
> > Hi Bob,
> > On Friday 24 April 2009 14:55:25 Bob Dalesio wrote:
> >> Do you know what the PUTF record processed by dbPutfield, and RPRO
> >> reprocess fields are used to accomplish?
> > I'm cross-posting this message to core-talk because while replying to
> > Bob's question I think I've found a couple of bugs associated with those
> > fields, and I'd like some more eyes on the issue.
> > I believe PUTF was provided as a way of telling a record that it's being
> > processed because someone changed one of its fields, so it can
> > distinguish between that and processing resulting from a forward link or
> > other scan mechanism.  I don't know of any record types that actually
> > look at PUTF, but there could be some.  However there are occasions where
> > PUTF lies, which makes it less useful (see below).
> > RPRO is needed to ensure that a pending asynchronous operation doesn't
> > cause the processing resulting from a put operation to be missed.  It is
> > less relevent to the record type, being mostly for internal use but is
> > related to the PUTF field.
> > Here's what I get from reading the source, which uses these two fields in
> > four places:
> > 1. If something [usually CA but it could be a dbpf command] calls
> > dbPutField() to set a field which is marked as PP, the routine will try
> > to process the record immediately.  If PACT is true however it can't, so
> > it sets RPRO to request reprocessing later; if PACT is false it sets PUTF
> > and calls dbProcess() to do the actual processing.
> > 2. Inside dbProcess(), if a record is found to be disabled because
> > DISA==DISV, both PUTF and RPRO are cleared immediately.
> > 3. When a record finishes processing, usually the last thing its
> > process() routine does is to call recGblFwdLink().  This checks and
> > clears the RPRO field and if set it sticks this record on the scanOnce()
> > queue to be run again as soon as possible.  recGblFwdLink() always clears
> > PUTF.
> > 4. In dbPutLinkValue() when a DB link from another record has the PP flag
> > set or points to the PROC field, if the destination record has its PUTF
> > field set it just sets RPRO.  If PUTF is not set, it calls dbScanLink()
> > to process the destination record.  This code really doesn't make any
> > sense to me.
> > I think there are two bugs in the above code, which make the PUTF field
> > less useful than it could/should be.
> > A) I suspect that in item 4 above, the dbPutLinkValue() code really
> > should be testing PACT not PUTF, and it should actually set PUTF before
> > the call to dbScanLink().  I have some vestigial memories that before
> > PACT was introduced the PUTF field was involved in asynchronous
> > processing, but I wasn't involved at the time so I may be confused about
> > that.
> > B) I also think that recGblFwdLink() should not clear PUTF if RPRO was
> > set, because the *next* time the record processes is the one that is due
> > to a call to dbPutField() or dbPutLink().  Instead it should be setting
> > PUTF if RPRO was set, and clearing it otherwise.
> > I propose to apply the attached change in src/db and would appreciate
> > comments from other core developers in case I've missed or misunderstood
> > something about how this is supposed to work.
> > Without this patch, PUTF is actually an almost useless field; the only
> > place where its value gets looked at is in the dbPutLinkValue() routine
> > as described above, unless there are some non-core record types that use
> > it.
> > - Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Re: some field definitions Tim Mooney
Re: some field definitions Andrew Johnson
Prev: Re: some field definitions Marty Kraimer
Next: Re: some field definitions Tim Mooney
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: some field definitions Tim Mooney
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
