All,
Attached is the result of the field support work I did at the codeathon.
There are two files - a gzipped patch file which is a patch against the
version of base I downloaded this morning labeled 17 April 2009, and a
makeBaseApp application which implements a default version of field
support.
New files in base are:
- src/dbStatic/fldSup.h - This declares the new field Support
structure and helper routines. There are a
number of forward structure declarations,
because I wasn't sure about the exact
order of include files.
- src/fldSupParams.c - additional dbStaticLib routines for saving
and restoring field support parameters.
- src/db/dbAccessFldSup.c - These routines have extracted all the if
(prset->function) (*prset->function)(param)
type calls for field support into one file
so they are done consistently. It also
reduces the number of changes needed in
dbAccess.c and the convert routines.
- src/db/dbAccessFldSup.h - header file for the above. Since all the
field support routines now have their
prototypes fully declared this uncovered a
number of times where longs were being
passed as int's in get_precision in the
convert routines. This is a bug and should
be fixed.
Other files changed (apart from Makefiles) are dbAccess.c and the
convert routines in src/db; dbBase.h, dbStaticLib.c and dbLexRoutines in
src/dbStatic, and iocInit.c. I have re-used the driver support registry
because I couldn't be bothered to implement something special for field
support (why do we have all these separate registry's anyway?).
The test app provides a default version of field support
(fldSupDefault.c) that provides a fairly traditional implementation for
cvt_dbaddr, get_array_info, put_array_info, get_units, get_precision,
get_graphic_double, get_control_double and get_alarm_double. It isn't
ready for prime time - there are a few printf's just to reassure you
that things are working. However it is basically there. The dbd for the
VAL field of a waveform record now looks like:
field(VAL,DBF_NOACCESS) {
prompt("Value")
asl(ASL0)
special(SPC_DBADDR)
fldSup(fldSupDefault_fset)
fldSup_bptr(BPTR)
fldSup_type(FTVL)
fldSup_nelm(NELM)
fldSup_nord(NORD)
fldSup_prec(PREC)
fldSup_units(furlongs)
fldSup_hopr(HOPR)
fldSup_lopr(LOPR)
fldSup_drvh(HOPR)
fldSup_drvl(LOPR)
fldSup_hihi(HOPR)
fldSup_high(HOPR)
fldSup_low(LOPR)
fldSup_lolo(LOPR)
pp(TRUE)
extra("void * val")
This is a lot longer than before, but you no longer need any of the
record support routines...
I hope its fairly obvious, but the values in the fldSup_ bits can be
other fields in the same record or constants. If you leave them out then
the corresponding field support routine returns S_db_noRSET.
As to what else to do, I was going to experiment with supporting arrays
and maybe strings a bit more. I am not sure what else it is good for,
but that may come.
I also don't quite know how this fits in with Andrew's code generation
work, but that is mainly because I don't know what that is. Andrew, is
there any reference for that anywhere - I would be interested in knowing
what you are getting at there - I know what you are doing in principal,
but not in practice.
Any comments are welcome.
Cheers,
Nick Rees
Principal Software Engineer Phone: +44 (0)1235-778430
Diamond Light Source Fax: +44 (0)1235-446713
fldSupBase_20090417.patch.gz Attachment:
testFldSup.tgz
| ANJ, 02 Feb 2012 |
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
