2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Local CA out links broken during PINI
Cc: EPICS Core Talk <[email protected]>, Ralph Lange <[email protected]>
Date: Fri, 20 Feb 2009 20:10:34 +0100
Andrew Johnson schrieb:
Bernd also replied:
We have an additional requirement: The record code of some records need
to know if it is processed normally, the first time at all or the first
time after the ioc became active. Up to now we solved this problem by
introducing a new field in those records and a function, which sets
these fields, is registered to the redundancy task (RMT). These records
are in a linked list. When the ioc becomes active the RMT sets the
fields to a value, so that the record code can see that the record is
processed first after becoming active.
A record type can always find out if this is a record's first-ever process() call by looking at the TIME field; if it's zero (the epoch) it has never called recGblGetTimestamp() for this record. That distinguishes one case. The other cases could be distinguished by making the IOC's initialization state available, so a record type could do something like
    if (iocInitState() == iocBuilding)
to detect the processing caused by PINI=YES, and
    if (iocInitState() == iocRunning)
for the normal processing state. It can also change the PINI field itself at runtime if it wants to cause re-processing at one of the other events.
Would this solve your requirement?
Well, partly yes. In one case not, I think: If an IOC have been "master" (active) and then "slave" and then it becomes "master" again after long time.... In this case the timestamp is not zero and iocInitState() would return "iocRunning". The record has no information, that it runs the first time after becoming "master" again.
-Bernd
Re: Local CA out links broken during PINI Andrew Johnson
Re: Local CA out links broken during PINI Ralph Lange
Prev: Re: Local CA out links broken during PINI Tim Mooney
Next: SIGALRM => SIGUSR1? Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Local CA out links broken during PINI Andrew Johnson
Next: Re: Local CA out links broken during PINI Tim Mooney
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
