2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Base 3.14.11 Release Timetable
To: Jeff Hill <[email protected]>
Cc: [email protected]
Date: Thu, 12 Feb 2009 13:55:49 -0600
Hi Jeff,
On Tuesday 10 February 2009 10:42:36 Jeff Hill wrote:
> Sounds ok, but I suspect that you are hoping that there is an
> implementation of the "client remembers what IOC it used to be connected
> to" change for that release? I reserve an option to whine depending on how
> cleanly that can be implemented :-). I could have a look at that and give
> you an estimate if you are interested.
Well since Mark Rivers seems to be happy with the 'Very slow reconnection to
medm' fix that you sent him I'm not too worried about that, so you're
probably off the hook for this release.
> It might also be interesting to implement an experimental 64 bit native
> windows build for this release.
We may have one little problem with that, somebody picked WIN32 as the OS
class name for Windows.  However that's cosmetic and can be ignored.
I have no objection to adding that as another architecture, although I don't
think Janet has access to a Win64 system yet, so we can't help you with
debugging it.  Note that several of our Perl scripts/modules have tests for
($^O eq "MSWin32") so you may have to make changes there if Perl uses a
different internal OS name.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Base 3.14.11 Release Timetable Andrew Johnson
RE: Base 3.14.11 Release Timetable Jeff Hill
Prev: Re: libCom tests results 32 bit compatibility mode on windows vista 64 Andrew Johnson
Next: Ideas for Codeathon Bernd Schoeneburg
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Base 3.14.11 Release Timetable Jeff Hill
Next: libCom tests results 32 bit compatibility mode on windows vista 64 Jeff Hill
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
