2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: libCom tests results 32 bit compatibility mode on windows vista 64
To: [email protected]
Date: Wed, 11 Feb 2009 12:41:55 -0600
Hi Jeff,
On Wednesday 11 February 2009 10:34:24 Jeff Hill wrote:
> Test Summary Report
> epicsUnitTestTest.t      (Wstat: 0 Tests: 1 Failed: 1)
>   Failed test:  1
> epicsStringTest.t        (Wstat: 768 Tests: 1 Failed: 0)
>   Non-zero exit status: 3
>   Parse errors: No plan found in TAP output
> epicsMutexTest.t         (Wstat: 0 Tests: 20 Failed: 1)
>   Failed test:  20
>   Parse errors: Bad plan.  You planned 19 tests but ran 20.
> Files=22, Tests=1559, 420 wallclock secs ( 0.19 usr  0.06 sys +  0.53 cusr
> 0.9  csys =  1.70 CPU)
> Result: FAIL
> Failed 3/22 test programs. 2/1559 subtests failed.
Please manually run the programs O.<arch>/epicsStringTest.exe and
O.<arch>/epicsMutexTest.exe and post their output.
The failure in epicsUnitTestTest.t is just the line terminators, which
indicates that your version of perl is not expanding "\n" to the "\x0d\x0a"
that your C library is generating - are you using cygwin perl?  This failure
doesn't worry me too much.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
libCom tests results 32 bit compatibility mode on windows vista 64 Jeff Hill
Prev: libCom tests results 32 bit compatibility mode on windows vista 64 Jeff Hill
Next: Re: Base 3.14.11 Release Timetable Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Ideas for Codeathon Bernd Schoeneburg
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
