One more aspect of this issue: currently the record timestamp is put on
all PVs that belong to the record, even though CA has no concept of a
record that would match this relation.
So - why not put this on the list of possible work packages for the next
codeathon?
Definitely something worth to be fixed, changing a behaviour that no one
should rely on (does someone?), and there are ways to improve this that
do not need a lot of changes in the code once we agree on how this
should be handled.
What do you think?
Ralph
On 29.01.2009 14:46 Benjamin Franksen wrote:
I think this is a known issue, it is at least as old as 3.13.9. EPICS posts
CA events when a non-VAL fields get written to, and it does so
independently of record support. There are two cases:
- If the field does not have the PP property, then the record is not
processed as a result of the put, and the CA event is posted with the old
timestamp.
- If the field /does/ have the PP property, then the record gets processed
as a result of the put, which woudl update the record's timestamp, but
processing comes /after/ EPICS base posts the event, thus the event has the
wrong (old) timestamp.
It should be clear that this means one should /not/ trust the history of
value changes as e.g. reported by the channel archiver (or simply the
output of camonitor) whenever the PV in question references a non-VAL
field. At least not w.r.t. the reported timestamps.
Is this going to be addressed any time soon?
Cheers
Ben
RE: Do we have any plan to support non-fixed size array? Jeff Hill
EPICS and interruptable system calls Mark Rivers
<2009>
<2009>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
EPICSv4
IRMIS
Talk
Bugs
Documents
Links
Licensing
