2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: RTYP field through the PV Gateway
To: Ralph Lange <[email protected]>
Cc: EPICS Core Talk <[email protected]>, "'Ernest L. Williams Jr.'" <[email protected]>
Date: Thu, 8 Jan 2009 11:34:18 -0600
Hi Ralph,
On Thursday 08 January 2009 07:56:53 Ralph Lange wrote:
> RTYP is a pseudo field: When a read request for a "*.RTYP" PV comes in,
> the CA client library  strips the ".RTYP" and converts it to a
> DBR_CLASS_NAME request.
Wrong, RTYP is one of two standard Record Attributes, pseudo-fields supported
by the database whose values are specific to the record type and can be set
(and new attributes created) using dbPutAttribute().  If the .RTYP handling
was an artifact of CA like you suggest I wouldn't be able to do this from the
ioc shell:
epics> dbgf mrk:stringinsyn.RTYP
DBR_STRING:          "stringin"
Go read section 6.14 of the AppDevGuide.  Attributes have been part of the IOC
since at least R3.13.0, just nobody uses them much...
> The only other case of CA-EPICSdb dependency (that I know of) is adding
> the ".VAL" extensionsto PVs without a field name. I don't know if this
> is done by the client or the server right now - it should be done on the
> server side for the same reasons.
Nothing explicitly adds .VAL to the PV name; when someone [currently RSRV, by
calling db_name_to_addr()] presents a PV name to dbNameToAddr() if the name
doesn't contain a field part it looks up the "VAL" field automatically.  Thus
this is already done in the server.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Re: RTYP field through the PV Gateway Ralph Lange
Prev: RE: RTYP field through the PV Gateway Jeff Hill
Next: Dates for a Codeathon at Brookhaven? Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: RTYP field through the PV Gateway Ralph Lange
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
