2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS build problem/question
Cc: Core-Talk <[email protected]>, [email protected]
Date: Mon, 27 Oct 2008 13:54:21 -0500
Hi Mark,
On Monday 27 October 2008 11:31:12 Mark Rivers wrote:
> In the 3.14.10 tree the linux-x86 build fails with the following error:
> ../O.Common/dxp.dbd.depends:3: *** target pattern contains no `%'.
> Stop.
> So the problem file is O.Common.dxp.dbd.depends.  On 3.14.8.2. this file
> contains the following:
> # DO NOT EDIT: This file created by mkmf.pl,v 1.5 2002/03/25 21:33:24
> jba Exp $
> ../O.Common/dxp.dbd : ../dxpSupport.dbd ../dxpRecord.dbd
> #Depend files must be targets to avoid 'No rule to make target ...'
> errors
> ../dxpSupport.dbd :
> ../dxpRecord.dbd :
> On 3.14.10 this file contains the following:
> jba Exp $
> ../O.Common/dxp.dbd : H:/epics/base-3.14.10/dbd/base.dbd
> ../O.Common/dxp.dbd : J:/epics/devel/asyn/4-10/dbd/asyn.dbd
> ../O.Common/dxp.dbd : J:/epics/devel/mca/6-10/dbd/mcaSupport.dbd
> ../O.Common/dxp.dbd : J:/epics/devel/calc/2-6-5beta/dbd/calcSupport.dbd
> ../O.Common/dxp.dbd : J:/epics/devel/sscan/2-6-2/dbd/sscanSupport.dbd
> ../O.Common/dxp.dbd : J:/epics/devel/autosave/4-4beta/dbd/asSupport.dbd
> ../O.Common/dxp.dbd : H:/epics/base-3.14.10/dbd/menuGlobal.dbd
> So only in 3.14.10 does that file contain absolute paths that are
> causing the problems.
The new version of the file is correct, whereas the old one was wrong since it
would not cause the dxp.dbd file to be rebuilt when one of its dependencies
from a different support application was modified.  This was changed in
R3.14.9 by the way, it's not a new behavior in R3.14.10.
The problem is that we're not putting that .depends file in the right
directory; it obviously needs to be architecture-specific to work properly
with Windows, so it should go into the O.$(T_A) directory rather than
O.Common.  However we currently only create the .depends file in the same
rule as the target it relates to.  Since there isn't a separate make rule for
it, moving the .depends file to O.$(T_A) would mean that only the first
architecture to build a shared installation would actually create
the .depends file.  The other architectures would have no reason to rebuild
the target file, so would never build its .depends file either.  This is
obviously broken behavior as far as their dependencies are concerned though,
and fixing it it would mean significant changes to the build rules which we
don't want to do on the day of the 3.14.10 release.
I don't want to delay R3.14.10 any longer, although it looks like we're going
to have to come out with a 3.14.11 release in a fairly short timescale to fix
up a number of issues like this.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
RE: EPICS build problem/question Mark Rivers
Prev: RE: EPICS build problem/question Mark Rivers
Next: RE: EPICS build problem/question Mark Rivers
Index: 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
