2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: R3.14.10-RC2 out on Thursday
Cc: Core-Talk <[email protected]>
Date: Wed, 08 Oct 2008 07:56:39 +0900
Hello Andrew,
>>> On Tue, 07 Oct 2008 10:00:29 JST,  Andrew Johnson <[email protected]> wrote;
> We are going to have to generate a second Release Candidate, which means the
> final release won't happen until after the INFN meeting.  This means that if
> you have any other fixes that can go into R3.14.10 without breaking anything,
> now is the time to commit them (before 1pm Chicago time on Thursday please).
> Mark Rivers discovered a serious but subtle bug in epicsRingPointer when
> compiled using a very recent gcc and run on an SMP system.  He and Eric
> managed to isolate this to two instructions being issued in the wrong order
> by the compiler optimizer, which Eric has fixed with judicious addition
> of 'volatile' modifiers.
> I am also about to commit a simplification of the exception classes in
> epicsThread.{h,cpp} which should resolve a compilation issue reported by
> Kazuro Furukawa on osf-alpha, and Janet will be making a few changes in
> configure and src/gdd/Makefile.
Thank you for your efforts.
We saw a minor issue yesterday.  In template, _APPNAME__SNCFLAGS
is used as an example.  However, there is no mechanisms to use
that macro in seq-2.0.12 if I understand it right, while
{source_file}_SNCFLAGS is used.
Regards.
Kazuro FURUKAWA <[email protected]>
 Linac&KEKB,  High Energy Accelerator Research Organization (KEK), Japan
 Telephone: +81-29-864-5200 x4316,  Facsimile: +81-29-864-0321
R3.14.10-RC2 out on Thursday Andrew Johnson
Prev: R3.14.10-RC2 out on Thursday Andrew Johnson
Next: fix to ipAddrToAsciiAsynchronous.cpp introduced after R3.14.9 Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
