Hi Kazuro,
Thanks for your report.
On Thursday 02 October 2008 08:46:53 Kazuro FURUKAWA wrote:
> As usual, osf-alpha needs the attached patch, that is almost the
> same as that against 3.14.9. I know it is dirty, but I don't know
> any other solution. And the resultant build and runtest logs are
> placed at
> <URL:http://www-linac.kek.jp/epics/osf/>
Jeff Hill has already commented on your modifications to comBuf.h and I have
just committed the change to CONFIG.Common.osf-alpha. As to your
implementation of epicsVsnprintf() we do not think this is necessary, since
osf-alpha is not the only target architecture that suffers from this
particular problem and . I have modified the text in the Application
Developers Guide that describes these two functions to make it clear that the
return value is not guaranteed. I may take out the return value tests from
the libCom/test/epicsStdioTest.c program too.
> Darwin-x86 showed error in the linkage stage of libCom shared lib,
> /usr/bin/c++ -o libCom.3.14.10pre1.dylib -dynamiclib ...
We already fixed the problem with the version number that affected both darwin
and WIN32, which was caused by my putting the "-pre1" part in the wrong
variable in CONFIG_BASE_VERSION. We have taken steps to ensure that this
shouldn't happen in the future, and it shouldn't have been an issue in
the -RC1 release.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- Re: EPICS Base R3.14.10-pre1 available for testing Kazuro FURUKAWA
RE: EPICS Base R3.14.10-pre1 available for testing Jeff Hill
<2008>
<2008>
