Hi Ernest,
On Wednesday 17 September 2008 00:01:58 Ernest L. Williams Jr. wrote:
> Target: MVME3100
> OS: vxWorks 6.6
> EPICS: base-R3-14-10-pre1
> Looks like, I failed on an exception.
The libCom tests are meant to be a standalone program run in a system without
an IOC running. Please boot vxWorks with no startup script, load *only* the
vxTestHarness.munch file and then execute epicsRunLibComTests — if everything
passes you should only need to post the overall summary message printed at
the end (at which point you'll have to Ctrl-C to get a shell back). RTEMS is
going to be similar using rtemsTestHarness.elf, although I'm not sure if we
build it properly for the CEXP configuration — Eric?
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- Re: vxWorks 6.6 and EPICS R3.14.10-pre1 libCom Test Harness Eric Norum
- vxWorks 6.6 and EPICS R3.14.10-pre1 libCom Test Harness Ernest L. Williams Jr.
<2008>
<2008>
