Subject: |
SLAC RTEMS and libCom test harness |
"Ernest L. Williams Jr." <[email protected]> |
To: |
EPICS core-talk <[email protected]> |
Date: |
Tue, 16 Sep 2008 20:21:06 -0700 |
Target: MVME6100
OS: RTEMS 4.9 snapshot
EPICS: R3.14.10-pre1
How to run the test Harness for our style of RTEMS at SLAC?
Also, still getting the conflicting message about NTP.
Any suggestions?
< st.cmd
<'st.cmd':
## Example RTEMS startup script
## You may have to change muon to something else
## everywhere it appears in this file
#< envPaths
chdir("../..")
0x00000000 (0)
# Load application object file.
ld("bin/RTEMS-beatnik/muon.obj")
0x009c89b8 (10258872)
dbLoadDatabase("dbd/muon.dbd")
0x00000000 (0)
muon_registerRecordDeviceDriver(pdbbase)
0x00000000 (0)
## Load record instances
dbLoadRecords("db/dbExample1.db","user=ernesto")
0x00000000 (0)
dbLoadRecords("db/dbExample2.db","user=ernesto,no=1,scan=1 second")
0x00000000 (0)
dbLoadRecords("db/dbExample2.db","user=ernesto,no=2,scan=2 second")
0x00000000 (0)
dbLoadRecords("db/dbExample2.db","user=ernesto,no=3,scan=5 second")
0x00000000 (0)
dbLoadRecords("db/dbSubExample.db","user=ernesto")
0x00000000 (0)
dbLoadRecords("db/iocAdmin-template.db","IOCNAME=muon")
0x00000000 (0)
## Set this to see messages from mySub
#var mySubDebug 1
iocInit()
Starting iocInit
## EPICS R3.14.10--lcls1 $$Name: R3-14-2_branch $$ $$Date: 2008/09/16
16:32:45 $$
## EPICS Base built Sep 16 2008
0x00000000 (0)
bspExtVerbosity=0
0x00000000 (0)
## Start any sequence programs
seq(&sncExample,"user=ernesto")
SEQ Version 2.0.11: Tue Sep 16 19:33:35 2008
Spawning state program "sncExample", thread 0xa010022: "sncExample"
0x0a010022 (167837730)
Cexp>rtems_bsdnet_get_ntp() Can't bind socket: Address already in use
Cexp>ld("../../base/base-R3-14-10/bin/RTEMS-beatnik/rtemsTestHarness.obj")
Symbol 'epicsThreadGetPrioritySelf' already exists
Symbol 'epicsTimeFromTime_t' already exists
Symbol 'epicsSnprintf' already exists
Ernest
libCom tests and a softIOC on Linux hosts Ernest L. Williams Jr.
vxWorks 6.6 and EPICS R3.14.10-pre1 libCom Test Harness Ernest L. Williams Jr.
<2008>
<2008>
