Hi Ben,
On Tuesday 08 July 2008 19:54:29 Ben Franksen wrote:
> The problem might be solved by suitable generalization. I am thinking about
> extensible syntax with pluggable handlers, an idea I've been pondering for
> a long time. This would have a wide range of possible applications,
> including pluggable field properties like 'copy_to_partner' as proposed by
> Bernd, while retaining complete backward compatibility. Let me explain what
> I mean.
Funny, a pluggable parser is one of my plans for the future, although there
are a number of other major jobs that need doing first. We actually need two
separate parsers since the IOC isn't going to be reading DBD files in the
future, all that information will be compiled into the generated binary.
The DBD files will still be needed though, they provide the meta-data for the
DB files, and any plugin for a DB file parser must be described somehow in a
DBD file to allow VDCT to understand and generate the DB file. This is
slightly contrary to your "unspoken assumption" about the parser ignoring
items it doesn't understand — DBD files must declare all of the information
needed to parse DB files so that generic tools like VDCT can understand and
create them properly.
Parsing of DBD files (record, device, driver, menu, registrar, function and
variable definitions) will be done at compile time using Perl code that
already exists (at this stage we're mostly just doing text manipulation and
generating C code from the DBD descriptions, so Perl is much more efficient
than writing it in C). Breaktables will be read at runtime from DB files and
are ideal for pluggable interpretation on the IOC.
Unfortunately Bernd needs to add information to the field descriptions which
get converted to C structures. This may have to be incorporated before Base
gets built, although it might be feasible to implement something like the
generic info items into the record field descriptors — that should be
sufficient for his purposes.
> Currently all syntax for db and dbd files is hard-coded into the parser.
> That, however, need not be the case. The grammar itself is very simple and
> regular: there is exactly one aggregate syntactical structure which I will
> call <definition>. A definition consists of a <head> of the form:
> <keyword> (<argument>,...)
> optionally followed by a <body>:
> { <definition> ... }
> where an <argument> is either a number, or a quoted string (unrestricted
> charset), or a bareword (restricted charset). The top-level is simply a
> sequence of definitions (like the inside of a body).
With one exception: the body of a breaktable currently comprises a free-form
list of raw+converted number pairs, space or comma separated. I'm planning
to change that syntax in R3.15 to match the above scheme, using the
keyword "point" with two arguments.
I don't have time to comment further now, and I'll be on vacation all next
week. However I would be very interested in help writing a pluggable DB file
parser; feel free to think about the new DBD file syntax that describes DB
parser plugins...
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- Re: IOC Redundancy in R3.14.10 Benjamin Franksen
- IOC Redundancy in R3.14.10 Schoeneburg, Bernd
- Re: IOC Redundancy in R3.14.10 Andrew Johnson
- Re: IOC Redundancy in R3.14.10 Ben Franksen
Re: IOC Redundancy in R3.14.10 Schoeneburg, Bernd
Re: Plans and Dates for 3.14.10 Release Andrew Johnson
<2008>
<2008>
