Hi Andrew,
I am sorry not having understood everything last time. You did a lot of
work again - examples also, thank you for that. The solution that you
have implemented looks very nice to me, because I do not like
conditional compilation as well. It took some time, but now I
understood your new taskwd functions. taskwdMonitorAdd gives a maximum
of flexibility for adding redundancy, error loggers, restarter and so
on. Now there will be no redundancy-dedicated code in base, thats fine.
The additional field attribute (copy to partner ioc: yes/no) is not
implemented in this way. I have no good idea how to decide this without
base modification.
The interface between Epics and the RMT will be in a separate module,
because RMT has no Epics calls inside.
Is it possible to control the ioc (redundancy status) by just using the
top level functions iocPause and iocRun?
Bernd
Andrew Johnson wrote:
Hi Bernd,
On Thursday 03 July 2008 09:01:13 Schoeneburg, Bernd wrote:
I want to remind you that we are highly interested in base modifications
for IOC redundancy.
As I have said to you before, the next release *will* allow you to implement
redundancy without modifying Base, although not using the patches that you
developed.
The proposed model gives maximal freedom of usage.
-- If the define (REDUNDANCY) is not done, Episc runs as usual and no
additional object code is loaded.
I am less worried about adding a small amount of additional code than I am of
getting the plug-in interface wrong. I do not like your conditional
compilation solution because it makes the result hard to test (you have to
completely rebuild Base with the conditional in the other state to be
completely sure it compiles properly), and it requires me to ship a copy of
your rmtDrvIf.h file with Base (which makes it hard for you to make any
changes to that file).
I am attaching a file which should become part of the Redundancy Monitor and
hooks into the interfaces I am providing. You won't be able to use this yet
because I haven't committed the parallel changes that are needed to Base, but
it shows you that it will be possible to make an IOC redundant without adding
more code to Base. This source code compiles without errors on my system,
although it won't link because I don't have the rmtRegister() routine or the
rest of the RMT subsystem. It is likely that you'll have to make some
changes, but I think the majority of this code is correct.
I accept that you need to be able to control some of the internal threads
inside the IOC, and as a result I am adding a series of 'xxxPause()'
and 'xxxRun()' routines to the various internal subsystems, as well as adding
top level 'iocBuild', 'iocPause' and 'iocRun' commands (in a redundant IOC
you will use 'iocBuild' instead of 'iocInit' in the startup script, ensuring
that the server and scan tasks are not started). While doing that I have
also been cleaning up the startup and shutdown procedure for the IOC, so
there is some advantage in this work for others as well.
After some more tests early next week, I will be committing my changes to CVS
and you'll be able to try them out.
- Andrew
- Re: IOC Redundancy in R3.14.10 Andrew Johnson
- IOC Redundancy in R3.14.10 Schoeneburg, Bernd
<2008>
<2008>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
