Eric Norum wrote:
> Andrew Johnson wrote:
../../asyn/devEpics/devAsynInt32.c: In function 'processMbbo':
../../asyn/devEpics/devAsynInt32.c:717: warning: assignment from
incompatible pointer type
../../asyn/devEpics/devAsynUInt32Digital.c: In function 'processMbbo':
../../asyn/devEpics/devAsynUInt32Digital.c:578: warning: assignment
from incompatible pointer type
../../asyn/devGpib/devCommonGpib.c: In function 'devGpib_initMbbi':
../../asyn/devGpib/devCommonGpib.c:657: warning: assignment from
../../asyn/devGpib/devCommonGpib.c: In function 'devGpib_initMbbo':
../../asyn/devGpib/devCommonGpib.c:839: warning: assignment from
On what compiler? I get no warnings for those -- the LHS and RHS of the
assignments are both 'unsigned long *'.
I didn't look at them closely before, sorry; this is GCC on a 64-bit
machine with some uncommitted changes I have in in my tree for 64-bit
systems that change the expansion of DBF_ULONG fields from 'unsigned
long' to 'epicsUInt32', etc.
This all relates to differences between db_access.h and dbAccess.h. For
code using db_access.h as provided by CA, DBF_LONG maps to an epicsInt32
(which is actually an int), whereas for code using dbAccess.h from the
database a DBF_LONG used to map directly to a regular long. On 64-bit
CPUs though these two are not synonymous.
Despite this in most cases the existing database code is self-consistent
and works Ok on 64-bit systems, but there are a few obscure spots where
bugs show up, such as when requesting a DBR_GRAPHIC_DOUBLE through CA
from a 64-bit IOC (IIRC the precision value is wrong). I think it's
important that R3.14.10 properly supports 64-bit systems, so something
has to be done.
I recently worked on fixing the database and dbAccess to change code
that uses 'long' to make it use epicsInt32 instead. My changes only
affect the field types generated when expanding the record.dbd files,
not the recGbl APIs or RSET routine arguments, so the modifications
needed in the record supports as a result of this are mostly minor and
in many cases zero.
Unfortunately if I commit these changes (which provide a comprehensive
solution) this will probably require *some* out-of-tree device and
record support changes to match, as in the above warnings from asyn
which are from pointers to the DBF_LONG state value fields (ZRVL etc) of
the MBB* record types.
It might be possible to reduce the impact of the fix while still getting
the IOC to work properly on 64-bit CPUs by not making DBF_LONG fields
become an epicsInt32 type. In this case, my current changes would move
to the main trunk for the R3.15 release.
My question for general developer discussion is therefore which solution
should we adopt? Do it properly in R3.14.10, so on all architectures a
DBF_LONG is 32 bits wide but some external device and record support
code needs changing, or just fix up the code in R3.14.10 so it works on
64-bit IOCs but a DBF_LONG field is architecture-specific?
I am inclined to do it properly in R3.14.10. Comments?
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- RE: Fixes for 64-bit CPUs Jeff Hill
- A modern DVCS would help (was: Fixes for 64-bit CPUs) Ben Franksen
Re: zombies Artem Kazakov
<2008>
<2008>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
EPICSv4
IRMIS
Talk
Bugs
Documents
Links
Licensing
