g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  Index 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013
Subject: Re: CR/CSR support in EPICS
To: "Ernest L. Williams Jr." <ernesto@slac.stanford.edu>
Cc: EPICS core-talk <core-talk@aps.anl.gov>, Sheng Peng <pengs@slac.stanford.edu>, strauman@MAILBOX.SLAC.STANFORD.EDU
Date: Thu, 08 May 2008 10:03:58 -0500
Hi Ernest,
Ernest L. Williams Jr. wrote:
We continue to see VME boards showing using CR/CSR.
Our hardware guys want to try new things.
Will the changes proposed by Eric Bjorkland make it into the next release of EPICS?
I believe Eric B. made some changes to devLib?
If someone wants to develop a patch to add CR/CSR support to devLib I'll be happy to work with them and integrate the results into Base. There are a number of things in devLib that need some work doing on them, but nothing is going to happen unless someone actually implements them (this is an open source collaboration...).
- Andrew
"Talk is cheap. Show me the code." -- Linus Torvalds
Prev: Re: Listing channels Noboru Yamamoto
Next: Re: zombies Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
