Andrew Johnson wrote:
No, don't. Apply the attached patch instead, which is a diff between
R3.14.9 and the current head of the R3.14 branch and should work in all
timezones.
The Posix spec apparently does not require that a time_t be expressed in
seconds, although Unix historically has used that. The existing
(broken) code does not make that assumption, and neither does my patched
version (which I did tell Peter about several months ago), but a using
constant probably does.
Oops, maybe it *doesn't* actually solve Peter's problem, but it should
be the basis of any fix. Maybe we have to drop the mktime() calls
[unfortunately there's no posix call gm_mktime()] but could just divide
the constant by this->time_tSecPerTick?
Jeff, comments?
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right. When he states that something
is impossible, he is very probably wrong. -- Arthur C. Clarke
- Re: Problems within epicsTime.cpp Kay-Uwe Kasemir
- Problems within epicsTime.cpp Denison, PN (Peter)
- Re: Problems within epicsTime.cpp Andrew Johnson
RE: Problems within epicsTime.cpp Denison, PN (Peter)
<2008>
<2008>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
