Andrew Johnson wrote:
Modified
# source files
(16) base-3.14.9/src/makeBaseApp/top/configure/RELEASE
The following lines are added for supporting iocRedundancy package:
#If using iocRedundacy package, point REDUNDANCY at its top
directory:
#REDUNDANCY=$(EPICS_BASE)/../modules/soft/iocRedundancy
(17) base-3.14.9/src/makeBaseApp/top/exampleApp/src/Makefile
The following lines are added for building redundant IOC application:
# NOTE: To build redundant IOC application, REDUNDANCY must be
defined
# in the <top>/configure/RELEASE file
ifneq ($(REDUNDANCY),)
_APPNAME__DBD += rmt.dbd
_APPNAME__DBD += cce.dbd
_APPNAME__DBD += snlexec.dbd
_APPNAME__LIBS += rmt
_APPNAME__LIBS += cce
_APPNAME__LIBS += snlexec
endif
I don't see the need to include links to the redundancy subsystem in the
makeBaseApp example template; the majority of EPICS users won't be using
the redundancy system, and I'd prefer not to confuse beginners with
information that is of no use them (that being the main purpose of the
makeBaseApp templates).
The additions necessary to create a redundant IOC just need to be
documented with the redundancy system, which could provide its own
makeBaseApp templates if it desires (makeBaseApp.pl can be told to look
in a different location for its templates).
Have you tested building a redundant IOC without an entry for SNCSEQ in
its configure/RELEASE file? I suspect the above would not be sufficient
to cover this case, assuming it is possible to build such an IOC.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right. When he states that something
is impossible, he is very probably wrong. -- Arthur C. Clarke
- Re: Redundancy Patch: makeBaseApp Liu, Gongfa
- Redundancy Patch: makeBaseApp Andrew Johnson
Re: Redundancy Patch: libCom Andrew Johnson
Re: Redundancy Patch: rsrv Andrew Johnson
<2007>
<2007>
