Modified
# source files
(16) base-3.14.9/src/makeBaseApp/top/configure/RELEASE
The following lines are added for supporting iocRedundancy package:
#If using iocRedundacy package, point REDUNDANCY at its top
directory:
#REDUNDANCY=$(EPICS_BASE)/../modules/soft/iocRedundancy
(17) base-3.14.9/src/makeBaseApp/top/exampleApp/src/Makefile
The following lines are added for building redundant IOC application:
# NOTE: To build redundant IOC application, REDUNDANCY must be
defined
# in the <top>/configure/RELEASE file
ifneq ($(REDUNDANCY),)
_APPNAME__DBD += rmt.dbd
_APPNAME__DBD += cce.dbd
_APPNAME__DBD += snlexec.dbd
_APPNAME__LIBS += rmt
_APPNAME__LIBS += cce
_APPNAME__LIBS += snlexec
endif
Index: src/makeBaseApp/top/configure/RELEASE
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/makeBaseApp/top/configure/Attic/RELEASE,v
retrieving revision 1.11.2.5
diff -u -b -r1.11.2.5 RELEASE
--- src/makeBaseApp/top/configure/RELEASE 26 Oct 2006 15:34:45 -0000 1.11.2.5
+++ src/makeBaseApp/top/configure/RELEASE 12 Nov 2007 18:22:33 -0000
@@ -18,6 +18,9 @@
TEMPLATE_TOP=_TEMPLATE_TOP_
+#If using iocRedundacy package, point REDUNDANCY at its top directory:
+#REDUNDANCY=$(EPICS_BASE)/../modules/soft/iocRedundancy
#If using the sequencer, point SNCSEQ at its top directory:
#SNCSEQ=$(EPICS_BASE)/../modules/soft/seq
Index: src/makeBaseApp/top/exampleApp/src/Makefile
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/makeBaseApp/top/exampleApp/src/Attic/Makefile,v
retrieving revision 1.37.2.6
diff -u -b -r1.37.2.6 Makefile
--- src/makeBaseApp/top/exampleApp/src/Makefile 8 Apr 2005 17:48:05 -0000 1.37.2.6
+++ src/makeBaseApp/top/exampleApp/src/Makefile 12 Nov 2007 18:22:33 -0000
@@ -48,6 +48,18 @@
_APPNAME__LIBS += xxxSupport
+# NOTE: To build redundant IOC application, REDUNDANCY must be defined
+# in the <top>/configure/RELEASE file
+ifneq ($(REDUNDANCY),)
+ _APPNAME__DBD += rmt.dbd
+ _APPNAME__DBD += cce.dbd
+ _APPNAME__DBD += snlexec.dbd
+ _APPNAME__LIBS += rmt
+ _APPNAME__LIBS += cce
+ _APPNAME__LIBS += snlexec
+endif
# NOTE: To build SNL programs, SNCSEQ must be defined
- Re: Redundancy Patch: makeBaseApp Andrew Johnson
Redundancy Patch: rsrv Andrew Johnson
Re: Redundancy Patches Eric Norum
<2007>
Re: Redundancy Patch: rsrv Liu, Gongfa
<2007>
