Modified
# source files
(1) base-3.14.9/src/db/dbAccess.c
dbPutSpecial() is added for CCE. This function is just a pipe to
call the static function putSpecial(). dbPutSpecial() is written
by John L. Dalesio and Bernd Schoeneburg originally.
(2) base-3.14.9/src/db/dbScan.c
Register periodic scan tasks at RMT. When the IOC is SLAVE, these
tasks are changed to be inactive.
(3) base-3.14.9/src/dbStatic/dbBase.h
enum type "redUp" and the element of struct dbFldDes "red_update"
are added for CCE. They are added by Bernd Schoeneburg originally.
(4) base-3.14.9/src/dbStatic/dbLexRoutines.c
Deal with pdbFldDes->red_update for CCE, by Bernd Schoeneburg
originally.
Added
(1) base-3.14.9/src/db/rmtDrvIf.h
The head file for RMT driver interface.
Index: src/db/dbAccess.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/db/dbAccess.c,v
retrieving revision 1.116.2.11
diff -u -b -r1.116.2.11 dbAccess.c
--- src/db/dbAccess.c 19 Dec 2006 16:20:47 -0000 1.116.2.11
+++ src/db/dbAccess.c 12 Nov 2007 18:22:33 -0000
@@ -15,6 +15,15 @@
* Date: 11-7-90
+modification history
+Oct.16,2007,Gongfa Liu dbPutSpecial() is added for CCE. This function is
+ just a pipe to call the static function putSpecial().
+ dbPutSpecial() is written by John L. Dalesio
+ and Bernd Schoeneburg originally.
#include <stddef.h>
#include <stdlib.h>
@@ -117,6 +126,19 @@
return(0);
+/* dbPutSpecial() is added for CCE. This function is just a pipe */
+/* to call the static function putSpecial(). */
+/* Originally by John L. Dalesio and Bernd Schoeneburg. */
+long epicsShareAPI dbPutSpecial(DBADDR *paddr,int pass)
+ long status;
+ status = putSpecial(paddr,pass);
+ return status;
static void get_enum_strs(DBADDR *paddr, char **ppbuffer,
struct rset *prset,long *options)
Index: src/db/dbScan.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/db/dbScan.c,v
retrieving revision 1.74.2.3
diff -u -b -r1.74.2.3 dbScan.c
--- src/db/dbScan.c 25 Aug 2005 13:04:51 -0000 1.74.2.3
+++ src/db/dbScan.c 12 Nov 2007 18:22:33 -0000
@@ -15,6 +15,13 @@
* Date: 07/18/91
+Oct.16,2007,Gongfa Liu register periodic scan tasks at RMT. When the IOC
+ is SLAVE, these tasks are changed to be inactive.
#include <epicsStdlib.h>
#include <stddef.h>
#include <stdio.h>
@@ -48,6 +55,31 @@
#include "recGbl.h"
#include "dbScan.h"
+/* added by Gongfa Liu */
+#include "epicsFindSymbol.h"
+#include "rmtDrvIf.h"
+#ifndef vxWorks
+#define BOOL int
+#define LOCAL static
+#define IMPORT extern
+#define TRUE 1
+#define FALSE 0
+#endif
+typedef struct {
+ BOOL run; /* scan task is running */
+ BOOL activeFlag; /* flag to check if loop is running */
+ const char* instanceName;
+ epicsThreadId tid; /* task id of driver instance */
+} scanPrivateType;
+static STATUS scanStart(scanPrivateType *ppvt);
+static STATUS scanStop(scanPrivateType *ppvt);
+static STATUS scanGetStatus(scanPrivateType *ppvt, drvStatusType *pstatus);
+static STATUS scanGetInfo(scanPrivateType *ppvt, char *pString, short *psize, char *prequestString);
/* SCAN ONCE */
int onceQueueSize = 1000;
@@ -483,10 +515,58 @@
double diff;
double delay;
+ /* added by Gongfa Liu */
+ /* register the periodicTask at RMT */
+ rmtEntryTabType scanRegistry;
+ scanPrivateType scanPvt;
+ const rmtInfoTabType *prmtInfoTab;
+ STATUS (*prmtRegister)() = NULL;
+ long status;
+ scanRegistry.type = "ScanPeriodic";
+ scanRegistry.instanceName = epicsThreadGetNameSelf();
+ scanRegistry.testTimeTypical = 0;
+ scanRegistry.pPrvt = (void *)&scanPvt;
+ scanRegistry.pStart = (RMTSUPFUN)scanStart;
+ scanRegistry.pStop = (RMTSUPFUN)scanStop;
+ scanRegistry.pTestIO = NULL;
+ scanRegistry.pGetStatus = (RMTSUPFUN)scanGetStatus;
+ scanRegistry.pShutdown = NULL;
+ scanRegistry.pGetInfo = (RMTSUPFUN)scanGetInfo;
+ scanRegistry.pGetUpdate = NULL;
+ scanRegistry.pStartUpdate = NULL;
+ scanRegistry.pStopUpdate = NULL;
+ scanPvt.instanceName = scanRegistry.instanceName;
+ scanPvt.tid = epicsThreadGetIdSelf();
+ scanPvt.run = FALSE;
+ scanPvt.activeFlag = TRUE; /* always TRUE when no testIO */
+ prmtRegister = (RMTSUPFUN)epicsFindSymbol("rmtRegister");
+ if(prmtRegister == NULL)
+ printf("Non redundant IOC!!!\n");
+ scanPvt.run = TRUE; /* let scan task be active */
+ else
+ status = (*prmtRegister)(&scanRegistry, &prmtInfoTab);
taskwdInsert ( epicsThreadGetIdSelf(), NULL, NULL );
epicsTimeGetCurrent(&start_time);
while(TRUE) {
- if(interruptAccept)scanList(psl);
+ /* if(interruptAccept)scanList(psl); */
+ /* changed by sbg and Gongfa Liu */
+ /* when the IOC is MASTER, scanPvt.run is TRUE *
+ if(interruptAccept && scanPvt.run == TRUE)
+ scanList(psl);
epicsTimeGetCurrent(&end_time);
diff = epicsTimeDiffInSeconds(&end_time,&start_time);
delay = psl->period - diff;
@@ -690,3 +770,68 @@
epicsMutexUnlock(psl->lock);
return;
+/* some functions for RMT driver interface. */
+ ppvt->run = TRUE;
+ printf("scanStart: ppvt->run=%d\n", ppvt->run);
+ return (OK);
+ ppvt->run=FALSE;
+ printf("scanStop: ppvt->run=%d\n", ppvt->run);
+ return (OK);
+ pstatus->mode = ppvt->run ? MODE_run : MODE_stop;
+ pstatus->testResult = TEST_undefined;
+ if ( epicsThreadIsSuspended(ppvt->tid) )
+ pstatus->error = INVALID_ERROR;
+ /*pstatus->mode = MODE_stop;* set again when the task is suspended */
+ else
+ pstatus->error = NO_ERROR;
+ pstatus->updateBusy = FALSE;
+ pstatus->inSync = TRUE;
+ pstatus->activeFlag = ppvt->activeFlag;
+ /* ppvt->activeFlag = FALSE; */ /* activeFlag shuold be kept TRUE when no TestIO */
+ return OK;
+ char scanTaskInfo[100];
+ sprintf(scanTaskInfo,"<XML><NAME>%s</NAME><STATUS>%s</STATUS></XML>",
+ ppvt->instanceName, ppvt->run ? "active" : "inactive");
+ if(prequestString && strlen(prequestString))
+ printf("%s: scanGetInfo with request\n", ppvt->instanceName);
+ else
+ printf("%s: scanGetInfo without request\n", ppvt->instanceName);
+ if (psize != NULL && pString != NULL)
+ if (*psize > sizeof(scanTaskInfo))
+ strcpy (pString, scanTaskInfo);
+ else
+ *psize = sizeof(scanTaskInfo)+1;
+ printf("%s\n", scanTaskInfo);
+ return OK;
+ else
+ return ERROR;
Index: src/db/rmtDrvIf.h
--- /dev/null 2007-11-05 13:05:14.280278523 -0600
+++ src/db/rmtDrvIf.h 2007-11-01 08:20:40.000000000 -0500
@@ -0,0 +1,63 @@
+* Copyright (c) 2006 Stiftung Deutsches Elektronen-Synchrotron,
+* Member of the Helmholtz Association, (DESY), HAMBURG, GERMANY.
+* Redundancy IOC codes are distributed subject to a Software License Agreement
+* found in file LICENSE.txt that is included with this distribution.
+#ifndef INCLrmtDrvIfh /* Include-file already inserted ? */
+#define INCLrmtDrvIfh /* defined macro flags insertion */
+#ifndef vxWorks
+#define OK 0
+#define ERROR -1
+typedef long STATUS;
+#endif
+typedef enum {UPDATE_full, UPDATE_data} updateMode;
+typedef enum {MODE_stop, MODE_run, MODE_standby, MODE_test} modeType;
+typedef enum {TEST_undefined, TEST_ok, TEST_error, TEST_timeout, TEST_aborted} testResultType;
+typedef enum {NO_ERROR, WARNING_ERROR, INVALID_ERROR} errorType;
+typedef struct {
+ modeType mode;
+ testResultType testResult;
+ errorType error;
+ int updateBusy; /* single update running */
+ int inSync; /* 1 == up-to-date with updates */
+ int activeFlag; /* set to TRUE by activity, cleared by getStatus() */
+} drvStatusType;
+/* special driver type for watchdog */
+#define WATCHDOG "WATCHDOG"
+typedef STATUS (*RMTSUPFUN)();
+typedef void (*RMTCALLBACK)(int, testResultType);
+typedef struct {
+ const char *type;
+ const char *instanceName;
+ unsigned short testTimeTypical;
+ void *pPrvt;
+ RMTSUPFUN pStart;
+ RMTSUPFUN pStop;
+ RMTSUPFUN pTestIO;
+ RMTSUPFUN pGetStatus;
+ RMTSUPFUN pShutdown;
+ RMTSUPFUN pGetInfo;
+ RMTSUPFUN pGetUpdate;
+ RMTSUPFUN pStartUpdate;
+ RMTSUPFUN pStopUpdate;
+} rmtEntryTabType;
+typedef struct {
+ const char *partnerIPPrivate;
+ short preferredMaster;
+} rmtInfoTabType;
+STATUS rmtRegister(rmtEntryTabType *prmtEntryTab,
+ const rmtInfoTabType **pprmtInfoTab);
+#endif /* end of insertions */
Index: src/dbStatic/dbBase.h
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/dbStatic/dbBase.h,v
retrieving revision 1.12.2.5
diff -u -b -r1.12.2.5 dbBase.h
--- src/dbStatic/dbBase.h 26 Oct 2006 16:05:23 -0000 1.12.2.5
+++ src/dbStatic/dbBase.h 12 Nov 2007 18:22:33 -0000
@@ -13,6 +13,14 @@
* Date: 03-19-92
+Oct.16,2007,Gongfa Liu enum type "redUp" and the element of struct
+ dbFldDes "red_update" are added for CCE.
+ They are added by Bernd Schoeneburg originally.
#ifndef INCdbBaseh
#define INCdbBaseh 1
@@ -53,6 +61,8 @@
typedef enum {CT_DECIMAL,CT_HEX} ctType;
/* access level types */
typedef enum {ASL0,ASL1} asLevel;
+/* redundant ioc update mode, for CCE. Originally by Bernd Schoeneburg */
+typedef enum {RED_NO_UPDATE,RED_INIT_COPY,RED_CONT_UPDATE} redUp;
/*Breakpoint Tables */
typedef struct brkInt{ /* breakpoint interval */
@@ -81,6 +91,8 @@
short promptgroup; /*prompt, i.e. gui group */
short interest; /*interest level */
asLevel as_level; /*access security level */
+ redUp red_update; /*redundant ioc update mode, for CCE */
+ /*Originally by Bernd Schoeneburg */
char *initial; /*initial value */
/*If (DBF_MENU,DBF_DEVICE) ftPvt is (pdbMenu,pdbDeviceMenu) */
void *ftPvt;
Index: src/dbStatic/dbLexRoutines.c
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/dbStatic/dbLexRoutines.c,v
retrieving revision 1.27.2.14
diff -u -b -r1.27.2.14 dbLexRoutines.c
--- src/dbStatic/dbLexRoutines.c 15 Nov 2006 23:33:31 -0000 1.27.2.14
+++ src/dbStatic/dbLexRoutines.c 12 Nov 2007 18:22:33 -0000
@@ -12,6 +12,15 @@
/*The routines in this module are serially reusable NOT reentrant*/
+Oct.16,2007,Gongfa Liu deal with pdbFldDes->red_update for CCE.
+ by Bernd Schoeneburg originally.
#include <stddef.h>
#include <stdio.h>
@@ -481,6 +490,7 @@
allocTemp(pdbFldDes);
pdbFldDes->name = epicsStrDup(name);
pdbFldDes->as_level = ASL1;
+ pdbFldDes->red_update = RED_CONT_UPDATE; /* for CCE, by Bernd Schoeneburg originally. */
for(i=0; i<DBF_NTYPES; i++) {
if(strcmp(type,pamapdbfType[i].strvalue)==0) {
pdbFldDes->field_type = pamapdbfType[i].value;
@@ -579,6 +589,18 @@
yyerrorAbort("menu not found");
return;
+ /* for CCE, by Bernd Schoeneburg originally. */
+ if(strcmp(name,"red_update")==0) {
+ if(strcmp(value,"NO_UPDATE")==0) {
+ pdbFldDes->red_update = RED_NO_UPDATE;
+ } else if(strcmp(value,"INIT_COPY")==0) {
+ pdbFldDes->red_update = RED_INIT_COPY;
+ } else if(strcmp(value,"CONT_UPDATE")==0) {
+ } else {
+ yyerror("Illegal value. Must be NO_UPDATE, INIT_COPY or CONT_UPDATE");
static void dbRecordtypeCdef(char *text) {
- Re: Redundancy Patch: db Andrew Johnson
Redundancy Patch: libCom Andrew Johnson
Redundancy Patch: iocsh Andrew Johnson
<2007>
Re: Redundancy Patch: libCom Andrew Johnson
<2007>
