Janet Anderson wrote:
Yesterday I committed changes to the EPICS base R3.14 branch and the
main trunk to allow the GNU make "-j jobs" option to work when building
EPICS base. I also made a change in the makeBaseApp.pl templates to
allow the -j option when building new ioc applications . There is a note
about the -j change in the R3.14 branch release notes.
Note that Janet's parallel build rules that support the -j option
require the use of $(eval ...) which was introduced in GNU Make version
3.81. Serial compilation still works on older versions of Make as
before, but if you give a -j option the build will fail since many of
the dependencies won't have been set.
On our 8-core Linux box the performance gain is obvious; building Base
for Linux and one RTEMS target came down from 6 minutes to 2 minutes in
my test.
- Andrew
When a distinguished but elderly scientist states that something is
possible, he is almost certainly right. When he states that something
is impossible, he is very probably wrong. -- Arthur C. Clarke
- GNU make multiple jobs option Janet Anderson
epicsTime.cpp Strangeness Denison, PN (Peter)
<2007>
<2007>
