EPICS
on Google+
Argonne National Laboratory
2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  Index 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012
Subject: Record fields of array type
From: Benjamin Franksen <benjamin.franksen@bessy.de>
To: core-talk@aps.anl.gov
Date: Thu, 19 Jul 2007 17:51:35 +0200
Good Afternoon,
I have now for the <n>th time explained to some desparate EPICS newbie all
the hoops one has to go through in order to create an array field for a new
record type. This is starting to get on my nerves, the more so because I
can't really tell them to go away and RTFM. Because, unfortunately, the
Fine Manual remains (shamefully?) silent about the fact that this is simply
not possible in any straight-forward manner, even if your array is supposed
to be of a fixed size. Instead one has to gather the information necessary
to work around this limitation from several places in the AppDevGuide
(Chapter 6.5, Chapter 11.5.7 and Chapter 15.2.3).
I dearly hope that with 3.15 there will be a dbd syntax for creating array
fields. Ideally there should be a way to specify another field whose value
at startup time determines the maximum number of elements. Life would be
almost perfect if in addition the runtime number of elements could be
specified in a similar way. It could be as simple as just one more
(possible) property for a field value like, for instance,
field(BLA,DBF_UCHAR) {
	array(NELM,NORD)
which might optionally allow a literal number for the first argument (for a
fixed size array) and where the second argument is optional (for arrays
that don't change their number of elements at runtime).
This would be a tremendously useful addition and would come at very low
cost. It is even backward compatible. Frankly, I am amazed that something
like this hasn't been done a long time ago.
Cheers
Ben
PS: I hope everyone reading the first paraggraph can mentally add the
missing smileys at the appropriate places themselves.
Prev: Re: FW: net_convert.h Andrew Johnson
Next: Pre-Release Tests of EPICS Base Ralph Lange
Index: 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
