I was able to check this a bit further before taking off to the EPICS
meeting at DESY:
It's even worse. Not only the CA server doesn't respond to name requests
anymore, even the IOC initialization doesn't finish.
In our case, the main communication tasks for the CAN field bus are
started at the final init step. If the AS file doesn't exist, CA doesn't
find the channels anymore. When I went to the IOC, I saw there was no
CAN traffic. Checking on the IOC's console, I found these tasks were not
started.
Looks as if IOCinit bails out somewhere in the middle of doing things if
the AS file doesn't exist.
Again: I agree that not giving any access would be the correct behavior
in that case. Not finishing the IOC startup is too much of a penalty.
Cheers,
Ralph
Ralph Lange wrote:
Ned -
I thought about this, too ... and I would completely understand if the
CA server does not grant access (neither read nor write) to any
channels in that case.
But actually it doesn't even resolve the names anymore, which is a
different thing, misleading, and probably neither appropriate nor
intended.
Ralph
Ned D. Arnold wrote:
Ralph -
I think the behavior that you observed is by design ... if one tries
to specify a configuration file that does not exist, it means you
intended to have *some* access control in place. If the file doesn't
exist, this is a fatal error and the safest thing to do is not allow
any access at all so someone will fix the problem immediately.
I actually remember this discussion with Marty Kraimer about 16 years
ago ...
Ned
RE: [Fwd: Track on control system evolution] News from EPICS - proposed topics Korhonen Timo
generalTime & EventTime Kalantari Babak
<2007>
<2007>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
