2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS R3.14.9 and vxWorks
To: "Ernest L. Williams Jr." <[email protected]>
Cc: "Kasemir, Kay" <[email protected]>, "Thompson, David H." <[email protected]>, EPICS Core Talk <[email protected]>
Date: Tue, 10 Apr 2007 16:00:09 -0500
Hi Ernest,
The first way is how we expect sites to manage this situation, which synchronizes IOC upgrades from vxWorks 5.5.x to 6.x at the same time as you upgrade them from one version of Base to the next. That's what we've done here in the past, and it encapsulates the change nicely.
This does not work.
Actually it can, but it takes a bit of effort...
For ioc application top you choose one version of EPICS in the
$IOCTOP/configure/RELEASE file. A given ioc application top can have many IOCs. Each IOC could have a
different version of vxWorks.  Especially, during any type of migration
period where one can't upgrade all IOCs at the same time.
That is one of the circumstances that causes us to start a new branch of our IOC application top. The two branches can co-exist for extended periods if necessary, but in general we try to make this as short a time as possible because it means you have to commit every change to CVS twice, once on each branch (NB doing a cvs update with two -j options can make this task easier). Application developers get tired of making the changes in both branches during that period, and this gives them an extra incentive to upgrade their older IOCs to the new version as soon as they can.
The option below is close to what I need.  Except that I need the
vxWorks 5.5.x and vxWorks 6.x targets to be built at the same time.
So, I am back to creating another set of CONFIG files in
$EPICS_BASE/configure/os
The target alias files I posted do exactly that - after adding those two files to configure/os you just add the vxWorks 6.x target architecture vxWorks6-ppc604_long to the CROSS_COMPILER_TARGET_ARCHS setting in your configure/CONFIG_SITE file as well as the vxWorks-ppc604_long target which handles the vxWorks 5.5.x systems.
Given our history with WindRiver, they will most likely make changes in
the future based on OS version number.
We now have the infrastructure in CONFIG.Common.vxWorksCommon to handle that...
We have newer BSPs from the same family (i.e. PowerPC) that don't have
the same compiler options.  Sometimes the compiler options are BSP
specific.
Do they fall under the same CPU type? Are you sure the different options are really necessary? There is often a difference between the options necessary to compile a vxWorks BSP and those necessary to compile application code; the BSP is more dependent on the particular CPU instructions, whereas applications code can be pretty generic.
We run our MC68060 CPUs (mv172, mv177) on code compiled for the MC68040 because the user-level code that the C and C++ compiler generates is not CPU-specific (there may be a very slight performance hit on the faster 68060 CPUs, but it's not noticable). Note that there is a standard PowerPC ABI which we could probably use for all PowerPC targets, thus omitting even the 603/604 distinction that we currently make.
Kay-Uwe Kasemir wrote:
Here at APS I never need to do that though; intead I include all my
Board-specific code in the vxWorks boot image and provide a  generic API
that the device support routines call; for example I have three
different implementations of my VME DMA API, which now works on the
VMEchip2, Universe-2 and Tempe chips; Marty's Generic Transient Recorder
support code doesn't care which kind of board it's running on, it  just
calls my API.
Does this mean that every vxWorks contains this DMA support,
even if the IOC doesn't need DMA?
Yes. It's not as if we're short of RAM, and these are usually only a couple of Kbytes which is nothing compared to the size of the bootfile.
How many driver modules of this type do you add to your vxWorks kernel?
The VME DMA API and VME A24 Memory allocation are the easy ones to separate out; there are others such as the VME Bus Error handler that I consider more a part of the BSP. WRS already provide things like sysBusToLocalAdrs() and the AUX Clock, and I think of these as just a further extension to those kinds of facilities.
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
Re: EPICS R3.14.9 and vxWorks Ernest L. Williams Jr.
Re: EPICS R3.14.9 and vxWorks Andrew Johnson
Prev: Re: EPICS R3.14.9 and vxWorks Ernest L. Williams Jr.
Next: Re: EPICS R3.14.9 and vxWorks Ernest L. Williams Jr.
Index: 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
