2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS R3.14.9 and vxWorks
Cc: "Kasemir, Kay" <[email protected]>, "Thompson, David H." <[email protected]>, EPICS Core Talk <[email protected]>, [email protected]
Date: Tue, 10 Apr 2007 15:23:21 -0400
On Tue, 2007-04-10 at 11:20 -0500, Andrew Johnson wrote:
> Hi Ernest,
> Ernest L. Williams Jr. wrote:
> > I suppose there will be some sites that move into vxWorks 6.x but still
> > have vxWorks 5.5 targets as well.  What recommendation do you have to
> > handle this?  We could have to separate versions of EPICS BASE.
> > Does no good to change the VXWORKS version number in the config files as
> > it will simply overwrite libraries for vxWorks 6 or 5 depending on which
> > one you built first.
> There are two ways to handle this situation: Use a completely separate
> installation of EPICS Base (the best way to do this is just to bump up
> your local version number for Base; in our case we'd go from 3-14-9-asd1
> to 3-14-9-asd2 for example), or create your own target architecture
> which derives from one of the standard ones.  The first way is how we
> expect sites to manage this situation, which synchronizes IOC upgrades
> from vxWorks 5.5.x to 6.x at the same time as you upgrade them from one
> version of Base to the next.  That's what we've done here in the past,
> and it encapsulates the change nicely.
This does not work.
For ioc application top you choose one version of EPICS in the
$IOCTOP/configure/RELEASE file.
A given ioc application top can have many IOCs.  Each IOC could have a
different version of vxWorks.  Especially, during any type of migration
period where one can't upgrade all IOCs at the same time.
This indeed will be our case.
The option below is close to what I need.  Except that I need the
vxWorks 5.5.x and vxWorks 6.x targets to be built at the same time.
So, I am back to creating another set of CONFIG files in
$EPICS_BASE/configure/os
Given our history with WindRiver, they will most likely make changes in
the future based on OS version number.
> If you really want to create your own target architecture instead, the
> difference with R3.14.9 is that the infrastructure for vxWorks 6 is now
> built in, so you only need to create two files in configure/os to do
> this; I call this target aliasing:
> CONFIG.Common.vxWorks6-ppc604_long
> # Definitions for vxWorks6-ppc604 targets with >32MB of RAM
> # Site-specific overrides go in CONFIG_SITE.Common.vxWorks6-ppc604_long
> # Inherit the settings from vxWorks-ppc604_long
> include $(CONFIG)/os/CONFIG.Common.vxWorks-ppc604_long
> # Site Specific definitions for the vxWorks6-ppc604_long target
> -include $(CONFIG)/os/CONFIG_SITE.Common.vxWorks-ppc604_long
> VXWORKS_VERSION = 6.3
> WIND_BASE = /usr/local/vw/vxWorks6.3-$(ARCH_CLASS)
> >> Problems with vxWorks build with new config file structure:
> >>(1) Can't build for vxWorks 5.5.X and vxWorks 6.X
> >>This is not good. Since our production environment includes both.
> >>So, vxWorks-ppc604 gets overwritten by second build of EPICS BASE
> >>against a different version of vxWorks.  I am sure that other sites
> >>that move to vxWorks 6 will experience this.
> This is not a problem if you just synchronize a vxWorks version upgrade
> with a Base version upgrade, which could be just a local version number
> increase.
> >>I think we should have the config files contain vxWorks major version
> >>and BSP name like before.  Looks like you allow RTEMS to do this?
> The generated RTEMS IOC binary includes all the OS/BSP code, therefor
> the target has to define the BSP to be used.  On vxWorks the OS/BSP code
> is currently separate, and there's nothing in the IOC code which needs
> to be specific to anything more than the CPU.  We stopped including the
> BSP name in the EPICS target name when we found we were compiling the
> same code 4 times with the *exact* same compiler options for the mv162,
> mv167, mv172 and mv177 targets.
We have newer BSPs from the same family (i.e. PowerPC) that don't have
the same compiler options.  Sometimes the compiler options are BSP
specific.
> >>For example, we are starting to use the altivec support on the
> >>MVME5110 but the MVME5100 does not have altivec support.
> >>We could have vxWorks-ppc604_altivec, I guess.
> That target already exists in R3.14.9, but unfortunately it is broken; I
> think the fix is for epicsThreadCreate() to set the VX_ALTIVEC_TASK flag
> on altivec builds for the IOC to run properly. I've not tried to do this
> yet, but it shouldn't be hard to do.
Sounds good.
> >>Another example is using
> >>the BSP/target name to discover whether we have a UNIVERSE or Tsi148
> >>interface for a DMA driver that we may write.  Having, the scheme that
> >>we used last time just turns into a bit more compile time and disk
> >>space, right?
> You can use the above target aliasing technique if you really want to
> encode BSP information into your target architecture name.
> Here at APS I never need to do that though; intead I include all my
> Board-specific code in the vxWorks boot image and provide a generic API
> that the device support routines call; for example I have three
> different implementations of my VME DMA API, which now works on the
> VMEchip2, Universe-2 and Tempe chips; Marty's Generic Transient Recorder
> support code doesn't care which kind of board it's running on, it just
> calls my API.
I like this method. :)
Ernest
> - Andrew
Re: EPICS R3.14.9 and vxWorks Andrew Johnson
EPICS R3.14.9 and vxWorks Ernest L. Williams Jr.
Prev: Re: EPICS R3.14.9 and vxWorks Andrew Johnson
Next: Re: EPICS R3.14.9 and vxWorks Andrew Johnson
Index: 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
