g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  Index 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013
Subject: Re: EPICS_TIMEZONE, TIMEZONE, vxWorks daylight saving
To: Kay-Uwe Kasemir <kasemirk@ornl.gov>, EPICS core-talk <core-talk@aps.anl.gov>
Date: Tue, 20 Mar 2007 10:25:59 -0500
Hello Kay,
Thanks for summarizing the problem.
From what you said, I guess the fix in Base would be for the vxWorks version of epicsTime_gmtime() to explicitly set the tm_isdst field to 0 - does that seem correct? If so, I propose to apply this patch in src/libCom/osi/os/vxWorks:
Index: osdTime.cpp
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/src/libCom/osi/os/vxWorks/osdTime.cpp,v
retrieving revision 1.9
diff -u -b -r1.9 osdTime.cpp
--- osdTime.cpp 12 Jul 2002 21:35:07 -0000      1.9
+++ osdTime.cpp 20 Mar 2007 15:17:43 -0000
@@ -29,6 +29,7 @@
     int status = gmtime_r ( pAnsiTime, pTM );
     if ( status == OK ) {
+        pTM->tm_isdst = 0;  /* vxWorks doesn't set this */
         return epicsTimeOK;
     else {
Those in favour say Aye.
Those against say Nay.
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
Re: EPICS_TIMEZONE, TIMEZONE, vxWorks daylight saving Kay-Uwe Kasemir
Prev: Re: calcoutRecord.h Andrew Johnson
Next: Re: EPICS_TIMEZONE, TIMEZONE, vxWorks daylight saving Kay-Uwe Kasemir
Index: 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
