g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  Index 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013
Subject: RE: Status Report
To: "'Matej Sekoranja'" <matej.sekoranja@cosylab.com>
Cc: "'Thomas Pelaia II'" <pelaiata@sns.gov>, "'Hiroyuki Sako'" <hiroyuki.sako@j-parc.jp>, "'Christopher K. Allen'" <ckallen@post.kek.jp>, "'Ernest Williams'" <ernesto@ornl.gov>, "'Kay Kasemir'" <kasemirk@ornl.gov>, "'NP Rees'" <nick.rees@diamond.ac.uk>, "'EPICS core-talk'" <core-talk@aps.anl.gov>, "John Faucett" <faucett@lanl.gov>
Date: Tue, 9 Jan 2007 10:57:28 -0700
Matej,
The stack traces you sent look very much like Mantis bug tracker entry 260 (see the diff below that fixes Mantis 260).
Was this observed when the MAC OSX client was linked with R3.14.8.2 (which does not have the patch described below) or was this observed when the MAC OSX client was linked with R3.14.9.x?
Thanks for your kind assistance and best regards,
Jeff
cvs diff: conflicting specifications of output style
--- cac.cpp 13 Feb 2006 16:33:46 -0000    1.180.2.33
+++ cac.cpp 6 Jun 2006 23:08:34 -0000     1.180.2.34
@@ -497,6 +497,12 @@
         if ( ! sockAddrAreIdentical ( &addr, &chanAddr ) ) {
             char acc[64];
             pChan->getPIIU(guard)->getHostName ( guard, acc, sizeof ( acc ) );
+            // It is possible for the ioInitiate call below to
+            // call the callback directly if queue quota is exceeded.
+            // This callback takes the callback lock and therefore we
+            // must release the primary mutex here to avoid a lock
+            // hierarchy inversion.
+            epicsGuardRelease < epicsMutex > unguard ( guard );
             msgForMultiplyDefinedPV * pMsg = new ( this->mdpvFreeList )
                 msgForMultiplyDefinedPV ( this->ipToAEngine,
                     *this, pChan->pName ( guard ), acc );
***** CVS exited normally with code 1 *****
From: Matej Sekoranja [mailto:matej.sekoranja@cosylab.com]
Sent: Saturday, December 23, 2006 4:45 PM
To: Jeff Hill
Cc: Thomas Pelaia II; Hiroyuki Sako; Christopher K. Allen; Ernest Williams; Kay Kasemir; NP Rees; EPICS core-talk
Subject: Re: Status Report
Tests of this type are a normal part of catime (the ca performance test and acctst (the ca regression test). For example the following code is in catime.
So I am not sure what is different with your situation. Do you see this problem only when access security files are not installed? I am at the moment testing with the example server. I will need to need to run the tests again against an ordinary IOC also.
* test_search ()
LOCAL void test_search (
unsignedunsigned)
unsigned i;
status = ca_search ( pItems[i].name, &pItems[i].chix );
SEVCHK ( status, NULL );
*pInlineIter = 1;
Re: Status Report Matej Sekoranja
Prev: RE: FW: [EPICS Base R3.14.x 0000204]: vxWorks soft reboot hang Jeff Hill
Next: Re: Status Report Matej Sekoranja
Index: 2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
