Hi Matej,
> While testing I've also found a (dead)lock in CA library.
> Simple lines as:
> for (p = 0; p < 1000; p++) {
> ca_create_channel (pvs[n].name,
pCB,
&pvs[n],
0,
&pvs[n].chid);
> /*epicsThreadSleep(0.1);*/
> can produce a (dead)lock.
> Lock happens randomly and can not be determined by a number of
issued requests.
> If I uncomment thread sleep, the lock disappears.
> I can provide a stack trace.
Tests of this type are a normal part
of “catime” (the ca performance test and “acctst” (the
ca regression test). For example the following code is in catime.
So I am not sure what is different
with your situation. Do you see this problem only when access security files
are not installed? I am at the moment testing with the example server. I will
need to need to run the tests again against an ordinary IOC also.
* test_search ()
LOCAL void test_search (
ti
*pItems,
unsigned
iterations,
unsigned
*pInlineIter
unsigned i;
int status;
for ( i = 0u; i <
iterations; i++ ) {
status = ca_search ( pItems[i].name, &pItems[i].chix );
SEVCHK (status, NULL);
status =
ca_pend_io ( 0.0 );
SEVCHK ( status, NULL );
*pInlineIter = 1;
[mailto:[email protected]]
Sent: Tuesday, December 19, 2006
12:35 PM
To: Jeff Hill
Cc: Thomas Pelaia II; Hiroyuki
Sako; John Galambos; Christopher K. Allen; Ernest Williams; Kay Kasemir; NP
Rees
Subject: Re: Status Report
I've been investigating this issue about CAJ deadlocking an IOC. I've
done lots of testing on the latest CAJ and an IOC but I've always failed to
deadlock the IOC.
From the stack traces of IOC deadlock (once, but later never
reproducible) and Mantis bug 268 mentioned by Jeff, I've concentrated on
access rights callback.
I've created a simple record counter:
... and changing access rights policy (so that IOC will generate ACL
callbacks to the client).
Then I've written a C client with preemptive context which blocks
(sleeps) in a connection callback.
Client blocked at first connection callback and server reported 18
created channels.
Looking at the "casr 10" I noticed that server's send queue
size for this particular blocking client is increasing up to its limit of 16k.
When this limit is reached the IOC is unable to create any new channel
from other clients (e.g. using caget utility).
So any badly written client (C or Java) can block (TCP buffers become
full), but should not affect other server's clients.
This was tested with 3.14.8.2.
Of course I
can’t know why or when any particular client application, or client
library implementation, might not be reading its input queue. There can be many
reasons. We can conclude that the server should not have such vulnerabilities,
and so I have a committed a patch (which redirects access security callbacks
through the event thread).
I tested this with 3.14.9-pre2 and the IOC does not block anymore.
Jeff, your patch seems to work.
I guess the deadlocking issue was present when CAJ didnot implement
flow control (first versions). Now CAJ has it implemented (and search algorithm
as well) and I guess the IOC deadlock cannot happen anymore.
Lock happens randomly and can not be determined by a number of issued
requests.
- Re: Status Report Matej Sekoranja
RE: EPICS on Tru64unix and HP-UX Jeff Hill
Re: EPICS on Tru64unix and HP-UX Kazuro FURUKAWA
<2006>
Re: EPICS R3.14.9 experiences Andrew Johnson
<2006>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
