Benjamin Franksen wrote:
Hi All,
there is another bug in mkmf.pl: If the full file path of a dependency
gets too long, it gets wrapped (and line-ending backslashes inserted at
the wrong places). In fact there is a call wrap(...) from module
Text::Wrap and its docs say: "Lines are wrapped at $Text::Wrap::columns
columns. $Text::Wrap::columns should be set to the full width of your
output device. In fact, every resulting line will have length of no
more than $columns - 1." which is clearly not acceptable for a file
that may contain arbitrarily long file names.
I have removed the wrapping code in mkmf.pl.
I have attached a patch to fix this, relative to R3.14.8.2 (apply in
configure/tools). The patch also removes the code that adds each
dependency as an additional target. The script said that this is to
avoid "no rule to make target..." warnings; I think this is an artefact
of the old (3.13) build system and is no longer necessary in 3.14.
I have removed the code adding each dependency as a target. Thanks.
Cheers
Ben
Index: mkmf.pl
RCS file: /opt/repositories/controls/epics/base/3.14/configure/tools/mkmf.pl,v
retrieving revision 1.1.1.1
diff -r1.1.1.1 mkmf.pl
28,30d27
< use Text::Wrap;
< $Text::Wrap::columns = 76;
34d30
< my %delim_match = ( q/'/ => q/'/, q/"/ => q/"/);
78c74
< my $line;
my $deps;
90,101c86,87
< $line = "$objFile : @includes";
< $fmtline = wrap ("", " ", $line);
< $fmtline =~ s/\n/ \\\n/mg;
< print $fmtline;
< print "\n\n";
< print "#Depend files must be targets to avoid 'No rule to make target ...' errors\n";
< #$line = "@includes";
< foreach $file (@includes) {
< print "$file :\n";
$deps = join(" \\\n ",@includes);
print "$objFile :$deps\n";
142,145c128,130
< return 0 if !($line =~ m/^[ ]*\#?[ ]*include/);
< return 0 if !($line =~ /^[\#?\s]*include\s*(['""'<])([\w\.\/]*)$delim_match{\1}/ix);
< return 0 if !$2;
< $incname = $2;
return 0 if not $line =~ /^#?\s*include\s*('.*?'|<.*?>|".*?")/;
$incname = substr $1, 1, length($1)-2;
print "DEBUG: $incname\n" if $debug;
158d142
- Patches for recognizing external dependencies Benjamin Franksen
- Re: Patches for recognizing external dependencies Andrew Johnson
- Re: Patches for recognizing external dependencies Benjamin Franksen
- yet another bug in mkmf.pl Benjamin Franksen
EPICS R3.14.9 experiences Rees, NP (Nick)
<2006>
Re: Problems with database breakpoint routines. Andrew Johnson
<2006>
