2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [solved:] no bug in build system (though questions remain)
To: [email protected]
Date: Fri, 15 Dec 2006 15:09:35 +0100
On Friday 15 December 2006 13:49, Benjamin Franksen wrote:
> It more or less amounts to removing line 148 from
> configure/tools/mkmf.pl. It is used for header files /and/ dbd files,
> as I just found out.
Correction: It is not _quite_ that simple.
> (BTW: mkmf.pl contains a bug: in line 143 file name matches are
> restricted to [\w\.\/]* instead it should be .* otherwise for
> instance 'include <x-y.h>' doesn't create a dependency on the header
> file x-y.h (and it really doesn't, I double-checked it this time)).
Correction: This is not the correct fix. The whole expression is
completely broken and works only by accident.
Working on both.
Ben
To the functional programmer's eye a loop is just a degenerate
form of linear recursion written in an adhoc special syntax.
Bug in generated MakefileInclude? Benjamin Franksen
Re: [solved:] no bug in build system (though questions remain) Andrew Johnson
Re: [solved:] no bug in build system (though questions remain) Benjamin Franksen
Prev: Re: [solved:] no bug in build system (though questions remain) Benjamin Franksen
Next: Re: C++ Exceptions from CAC-UDP on exit Ernest L. Williams Jr.
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: [Fwd: EPICS Base @ HP-UX: Volunteers wanted] Andrew Johnson
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
