Jeff Hill wrote:
The root problem here I suspect is that DB CA link code does not have a
shutdown procedure and therefore it is not destroying its CA context before
the process exits. So when the process rundown starts and the resources that
the UDP thread uses start to cease to exist then the UDP thread crashes.
If that is the problem the I agree we don't have much chance of fixing
it. The strange thing though is that it's reporting an unknown C++
exception, so there is probably still something there that's able to
catch whatever it being thrown. If we could modify the CAC-UDP task to
expect that exception we could at least suppress the warning message, or
convert it to something a little more innocuous.
What OS do you see this on? We might be able to attach with a debugger to
get more detail, but I suspect that we will only see that the above
suspicions are accurate.
I've only seen it on linux-x86 so far - I tried it on Solaris but it
didn't occur there, and I've not run the tests on vxWorks yet.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
- RE: C++ Exceptions from CAC-UDP on exit Jeff Hill
<2006>
<2006>
