2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: vxWorks 6.3 and EPICS R3.14.9-pre1
Cc: EPICS Core Talk <[email protected]>
Date: Tue, 05 Dec 2006 13:38:11 -0500
On Tue, 2006-12-05 at 10:09 -0600, Andrew Johnson wrote:
> Hi Ernest,
> Ernest L. Williams Jr. wrote:
> >         Note that for vxWorks 6.3 the WIND_HOST_TYPE has changed:
> >         WIND_HOST_TYPE = x86-linux2
> >         I will override the current definition in the following file
> >         "CONFIG_SITE.linux-x86.Common"
> Did that happen as of 6.3, or is it a 6.x thing do you know?  I can
> change the setting in one of the CONFIG files based on the vxWorks
> version, but I need to know which version to make the change from.
This is a 6.x thing.  All releases 6.0 thru 6.3 have the following:
$(WIND_BASE)/gnu/<gnu-version>-vxworks-<version>/x86-linux2
Ernest
> Thanks,
> - Andrew
Re: vxWorks 6.3 and EPICS R3.14.9-pre1 Andrew Johnson
vxWorks 6.3 and EPICS R3.14.9-pre1 Ernest L. Williams Jr.
Prev: Re: osiWireFormat.h problems Eric Norum
Next: Re: vxWorks 6.3 and EPICS R3.14.9-pre1 Andrew Johnson
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: vxWorks 6.3 and EPICS R3.14.9-pre1 Andrew Johnson
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
