2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: osiWireFormat.h problems
To: Jeff Hill <[email protected]>
Cc: "'Core talk list'" <[email protected]>
Date: Mon, 4 Dec 2006 13:34:22 -0600
On Dec 4, 2006, at 12:52 PM, Jeff Hill wrote:
Eric,
It would easier from my end if I could see the compiler errors before
changes were made.
Those were in my original message:
I did a CVS update this morning and can no longer build base:
/usr/local/rtems/rtems-4.7/bin/m68k-rtems4.7-g++ -B/usr/local/rtems/ rtems-4.7/m68k-rtems4.7/uC5282/lib/ -specs bsp_specs -qrtems -c - m528x -DUNIX -ansi -O4 -g -g -Wall - DMY_DO_BOOTP=NULL - DRTEMS_NETWORK_CONFIG_DNS_DOMAINNAME=aps.anl.gov - DRTEMS_NETWORK_CONFIG_DNS_DOMAINNAME=aps.anl.gov -I. -I.. -I../../../ include/os/RTEMS -I../../../include ../casw.cpp ../../../include/osiWireFormat.h: In function 'void AlignedWireGet (const T&, T&) [with T = short unsigned int]': ../../../include/osiWireFormat.h:109: instantiated from 'AlignedWireRef<const T>::operator T() const [with T = short unsigned int]'
../casw.cpp:154:   instantiated from here
../../../include/osiWireFormat.h:230: error: 'tmp' has incomplete type
../../../include/osiWireFormat.h:230: error: storage size of 'tmp' isn't known
make[3]: *** [casw.o] Error 1
make[2]: *** [install.RTEMS-uC5282] Error 2
make[1]: *** [ca.install] Error 2
make: *** [src.install] Error 2
norume@gnarly 224> /usr/local/rtems/rtems-4.7/bin/m68k-rtems4.7-g++ -- version
m68k-rtems4.7-g++ (GCC) 4.1.1
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Are you providing a new RTEMS specific osdWireFormat.h instead of just using
the one found in osi/os/default?
I'm just using the one in osi/os/default.
It is also possible that you are seeing a
warning that the osdWireFormat.h header file couldn't be found?
No.  The above is the entire output error message.
That might
be because the RTEMS specific gnu make "vpath" configuration for the libCom build does not allow osdWireFormat.h to be installed from the osi/ os/default
directory? It seems that that one of the above circumstances would be
necessary for you to see these errors.
Another possibility might be that your woes are specific to GCC 4.0 which is difficult to test as they have not installed it on any Linux system here and
you can't get gcc 4.0 at this time for cygwin. It doesn't seem to be
particularly likely that there would be problems with gcc 4.0 however
because the code involved looks quite standard and has compiled on many
compilers.
My OS X machines use gcc 4.0.1:
norume@ctlstrmvid0 18> g++ --version
powerpc-apple-darwin8-g++-4.0.1 (GCC) 4.0.1 (Apple Computer, Inc. build 5363)
Copyright (C) 2005 Free Software Foundation, Inc.
The RTEMS compiler is gcc-4.1.1 (as shown in my original message).
The gory details go like this. The WireAlias template is only needed for the primitive types where the byte swap can be done as an alias of an unsigned type {epicsInt8, epicsInt16, epicsInt32, epicsFloat32}. Closer inspection reveals that the WireAlias template is used only by the following template functions which assume that the byte swap can be done as an unsigned alias. Where that default assumption does not work, explicit versions of these template functions (ordinary functions with the same callable interface as the template functions) are provided in osdWireFormat.h for the appropriate
types where there might be architecture specific issues {epicsUInt16,
epicsUInt32, epicsFloat64, epicsOldString}. Because the explicit versions of
these functions do not use the WireAlias template then the explicitly
implemented types need not be supplied for the WireAlias template.
template < class T >
inline void WireGet ( const epicsUInt8 * pWireSrc, T & dst );
inline void WireSet ( const T & src, epicsUInt8 * pWireDst )
inline void AlignedWireGet ( const T & src, T & dst );
inline void AlignedWireSet ( const T & src, T & dst );
Furthermore, note that if the explicit function definitions are properly provided in osdWireFormat.h then it does not hurt to define the additional WireAlias types, but this shouldn't be done because it certainly adds unused source code and it also makes catching explicit function definitions missing
from an OS specific osdWireFormat.h less likely at compile time.
I will give you a call later today.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
RE: osiWireFormat.h problems Jeff Hill
Prev: RE: osiWireFormat.h problems Jeff Hill
Next: Re: osiWireFormat.h problems Ralph Lange
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: osiWireFormat.h problems Jeff Hill
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
