Eric Norum wrote:
On Nov 28, 2006, at 9:50 AM, Kay-Uwe Kasemir wrote:
For which we have to know where it all affects us: - register
access, I/O buffer encoding/decoding via mapped structures -
do-it-yourself inheritance from dbCommon to xyzRecord What else?
I think that I/O buffer encoding/decoding via *any* cast, not just
via mapped structures might be at risk.
I'm still not convinced that this is quite as big a problem as Eric
does. In his example, the code is breaking this C99 rule:
An object shall have its stored value accessed only by an lvalue
expression that has one of the following types: 74)
- a type compatible with the effective type of the object,
- a qualified version of a type compatible with the effective type of
the object,
- a type that is the signed or unsigned type corresponding to the
- a type that is the signed or unsigned type corresponding to a
qualified version of the effective type of the object,
- an aggregate or union type that includes one of the aforementioned
types among its members (including, recursively, a member of a
subaggregate or contained union), or
- a character type.
74) The intent of this list is to specify those circumstances in
which an object may or may not be aliased.
Note that the rule is only talking about accessing the stored value of
an object, it says nothing about how you do that, so I think the pointer
casting may be a bit of a red herring (it seemed to make no difference
in Eric's tests if he passed the value in using a char*, which would
make sense given the above rules - he never accessed the value as a char
and that's the only other unrelated type the above rules allow).
I don't think the code in Base breaks that rule very often if at all,
although it may not be particularly obvious since we do cast pointers to
char*, void* or void** and back. However, we never actually use a
double* to actually read a value from a long*, and that's where strict
aliasing optimization would be entitled to clobber our code. I think
our dbCommon* casts for record types all fall into the first option in
the rule, so I don't see them as being a problem.
I'm not saying that we have no aliasing problems, but I don't think
they'll be as widespread as you might think. For now we should turn on
-fno-strict-aliasing on those targets that use gcc 3.x or later, and
keep running and improving our test suite with it off to try and detect
any aliasing problems that gcc doesn't warn us about.
- Andrew
There is considerable overlap between the intelligence of the smartest
bears and the dumbest tourists -- Yosemite National Park Ranger
- Re: C strict aliasing rules Eric Norum
- C strict aliasing rules Eric Norum
- Re: C strict aliasing rules Benjamin Franksen
- Re: C strict aliasing rules Kay-Uwe Kasemir
- Re: C strict aliasing rules Marty Kraimer
<2006>
<2006>
