2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: C strict aliasing rules
To: Marty Kraimer <[email protected]>
Cc: Kay-Uwe Kasemir <[email protected]>, Core talk list <[email protected]>
Date: Tue, 28 Nov 2006 09:37:18 -0600
On Nov 28, 2006, at 9:23 AM, Marty Kraimer wrote:
Kay-Uwe Kasemir wrote:
Hi:
Do I understand correctly that the most likely impact for EPICS might be this type of code:
struct xyz_regs
    Word control;
    Word status;
void xyz_operate(char *vme_base)
    struct xyz_regs *xyz = (struct xyz_regs *) vme_base;
    xyz->control = 0x1234;
    if (xyz->status & 0x8000)
The mapping of C structures to hardware registers?
volatile should be used for all access to hardware registers.
volatile prevents compiler optimization.
Let's not get off on a tangent here. The problem Kay was describing was one of structure padding, alignment, endianness when using a structure to define the layout of hardware registers. The issue on the table is that of compilers imposing their strict aliasing rules, and what to do about that.
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
Re: C strict aliasing rules Kay-Uwe Kasemir
C strict aliasing rules Eric Norum
Re: C strict aliasing rules Benjamin Franksen
Re: C strict aliasing rules Eric Norum
Re: C strict aliasing rules Marty Kraimer
Prev: Re: C strict aliasing rules Marty Kraimer
Next: Re: C strict aliasing rules Kay-Uwe Kasemir
Index: 2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
